Best flame arrestor >
Best flame arrestor
Best flame arrestor
Old 03-17-2014 | 11:14 PM
  #31
OSO member "WETTE VETTE" did over 1000hp with a N/A 632 I believe.
MILD THUNDER is offline
Old 03-17-2014 | 11:26 PM
  #32
is it a pump gas engine?
mike tkach is offline
Old 03-18-2014 | 03:10 PM
  #33
SB
Yes. But not for the faint of heart. He put together himself but of course need a good pocket for what was done. Think he ran well over 120mph in his single engine cat.
Do a search...you'll find it. I believe 598cid or some where around there.
SB is offline
Old 03-18-2014 | 03:23 PM
  #34
rmbuilder's Avatar
MarineKinetics
Default Wette Vette
Bbc_598 Craig Miscowicz
10.78:1 true pump gas 598.
Attached Thumbnails Best flame arrestor-craig_send_2.jpg   Best flame arrestor-img_2450.jpg   Best flame arrestor-wette_vette.jpg
rmbuilder is offline
Old 03-18-2014 | 03:40 PM
  #35
onesickpantera's Avatar
Years ago I did a back to back run with and without my flame arrestor. I gained 0.00 mph by removing my flame arrestor. This was on a 500hp 502. But, my arrestor was the wire mesh kind which is the type I would recommend.
This is the one I had:
http://www.hardin-marine.com/p-14180...-arrestor.aspx
onesickpantera is offline
Old 03-18-2014 | 03:43 PM
  #36
I really like mine.. pretty unrestricted.
ICDEDPPL is offline
Old 03-18-2014 | 04:55 PM
  #37
That's what I'm talking about. Who makes that?
Black Baja is offline
Old 03-18-2014 | 04:57 PM
  #38
How much power did that thing make? And why the coated pistons?
Old 03-18-2014 | 05:02 PM
  #39
[ATTACH=CONFIG]520490[/ATTACH]
These particular flame arrestors supported 1200 on the dyno. Installing them on, for the last pull, the engine lost like 4hp. Wasnt my engines in the pic that made that kinda power, but i wish!
Old 03-18-2014 | 08:41 PM
  #40
On a max effort-ish N/A deal, you'll want to pay attention to the entry into the carb. Messing around on the dyno, I've seen a decent HP loss from those long flat flame arresters, even with the screens removed. There's even a considerable difference from just using different bases with no tops, with the flat ones being the worst. Air flow hates right angles.. If you imagine what the air looks like being forced into the carburetor, it's easy to visualize the difference between a nice tapered radius vs a flat plate and 90 deg edge.
HaxbySpeed is offline
