Baffled by apparent reversion issues with Lightning headers and mild cam >
Old 06-02-2014 | 08:51 AM
I'm also wondering if this might be a little bit that is getting sucked back on shutdown. My understanding is that this is when the risk of reversion is the highest. However, I would expect to just see the water in the one pipe that is sucking back.
Budman II is offline
Old 06-02-2014 | 10:05 AM
Since pictures are worth a thousand words, here are a couple of shots of the engine on the cart. This is the first test when I had the silent choice diverters mocked up. When I started seeing water in the tubes, I switched back to the original divorced collectors that have an inner pipe that effectively extends the dry part of the pipe and extra 9 inches or so. No change in the water in the primaries.
And here is a picture of the water that is showing up in the tubes. Like I said, it's not a whole lot, and so far no sign of any water in the oil, but this is after just a minute or two of idling at 800 RPM:
Old 06-02-2014 | 12:13 PM
Talked to Lightning, and he thinks it is reversion rather than condensation. He recommends using silicone in the joint where the inner pipe of the collector extension mates to the main collector. I will try that tonight.
Old 06-02-2014 | 12:14 PM
He also said they don't generally recommend using any kind of muffled tips or mufflers with their headers, although he did say that it should be OK with my cam specs.
Old 06-03-2014 | 06:37 AM
Here are a couple of pictures of the divorced collectors. As you can see, they have 4 or 5 holes in the tip about 3/8", and one in the bottom for water to come out. I was watching it run and it looks like a waterfall coming out of there. Seems like too much water to me. Might try to post a video of it running when I get my boogered up spark plug hole fixed (another story... )
I'm wondering if anyone can tell me for sure that the 5 holes go on top. Might have to call Lightning.
Old 06-03-2014 | 08:11 AM
Thats quite a bit of water in there buddy. My tails are super short and I had a 'waterfall' in there too but as far as I know it never made it any farther than the collector getting all wet.
Either way I didn`t like it so I sealed up the water holes (slits in my case)with SIX10 and had a guy weld in a pisser just to keep the mufflers cool. 3/4" bungs inside and all water overboard.
Better safe than sorry.
ICDEDPPL is offline
Old 06-03-2014 | 08:14 AM
What is SIX10? Thought about sealing up a couple of those holes and adding an exterior bung to the header collector to dump it overboard.
Old 06-03-2014 | 08:19 AM
I still have my Y-pipe in there. Toying with using that to dump the excess water instead of drilling another hole through the hull.
Can't believe I'm even having to worry about this with that mild cam and Lightnings. Leave it to Budman to find yet another clusterfuq. They just seem to follow me like a stray dog.
Old 06-03-2014 | 09:02 AM
Have you though about making the inner pipe longer?
fbc25el is offline
Old 06-03-2014 | 09:29 AM
Not really a good way to do that. Don't have the room.
