Baffled by apparent reversion issues with Lightning headers and mild cam >
Old 06-03-2014 | 06:08 PM
  #31
ICDEDPPL is offline
Old 06-03-2014 | 06:42 PM
  #32
budman,if you dont have any water in the oil you are worried for nothing.unless your headers are leaking you should be good.reversion happens at idle more than at rpm so quit worring,put the engine in the boat and GO BOATING,i am 99% sure you will be ok.i have seen your cam specs and real reversion should not be an issue.
mike tkach is offline
Old 06-03-2014 | 06:43 PM
  #33
i forgot to ask,what rpm is the engine idleing at?
Old 06-03-2014 | 07:04 PM
  #34
I agree with Mike .If you are getting a teaspoon of water in the bottom of headers after shutdown, could just be sweat .That cam isn't near big enough and has wide lobe centers to be a problem .FWIW when I run a seawater equipped motor I let the motor take all the water it wants out of a three hundred gallon tank through 1 1/4" hose.You'd be surprised how quick it will empty the tank .If I were you I would stick the motor in and run your boat..JMO
motor is offline
Old 06-03-2014 | 07:08 PM
  #35
SB
It's true. Engine's in garage's revert more than in a boat.
SB is offline
Old 06-03-2014 | 07:15 PM
  #36
there you go budman,you have been told from two wise men and my dumb azz.
Old 06-03-2014 | 07:25 PM
  #37
Looks like 3 sages to me, go boatn and enjoy your creation you've earned it
buck35 is offline
  #38
SB
What the hell is this crap below ?
Slip on ? Not welded ?
And holes spraying straight down into exhaust stream ?
Huh ? I don't get why, Yuk !
Yeh, I finally looked at your pics. I'm kinda horrified.
Originally Posted by Budman II
Here are a couple of pictures of the divorced collectors. As you can see, they have 4 or 5 holes in the tip about 3/8", and one in the bottom for water to come out. I was watching it run and it looks like a waterfall coming out of there. Seems like too much water to me. Might try to post a video of it running when I get my boogered up spark plug hole fixed (another story... )
I'm wondering if anyone can tell me for sure that the 5 holes go on top. Might have to call Lightning.
SB is offline
Old 06-03-2014 | 08:21 PM
  #39
Have you noticed any less water with the diverter closed and running through the Y pipe? If your Y pipe shutters are in good shape, it may very well help with your reversion. Shutters and flappers can have a check valve effect; allowing the engine to exhale while making it a little more difficult on the inhale(reversion). I'm only saying that this may lessen your reversion with your existing system. Any engine with valve overlap will have exhaust reversion, but I wouldn't think that your cam would be giving you big issues unless you have long idles through no wake zones. I wouldn't think your Lightnings would be contributing to your issue, BUT if you look at a CMI, the collector is dry and the water is plumbed into the tailpipe after a clever welded conical ring that looks to act as a dam as in the "turbulator" as found in the Merc 8.1 manifolds.
liquidlounge is offline
Old 06-03-2014 | 08:33 PM
  #40
Have you checked your timing?
excal27 is offline
