Easiest way - converting 502 to EFI >
Old 09-30-2014 | 12:27 PM
  #31
Originally Posted by ezstriper
you are wasting your time or going to need to spend lots of time of money to get that stuff to work at your power level...not going to work with 600+NA HP, ask around..
ezstriper is offline
Old 09-30-2014 | 12:33 PM
  #32
Why won't it work with the proper sized injectors and pump? Just telling me to ask others and I would be wasting my time doesn't really help me at all....
Superman09 is offline
Old 09-30-2014 | 08:06 PM
  #33
GPM
You can mix and match pieces and it will work but you might want to consider one of the self tune ECM's, they are a lot more user friendly.
GPM is offline
Old 09-30-2014 | 09:10 PM
  #34
I am liking the FAST EZ EFI and thinking of using that with a factory manifold/rail set-up with bigger injectors and pump.
Old 09-30-2014 | 09:29 PM
  #35
GPM
I know nothing about the factory manifold, you may want to see what it's HP limits are. The aftermarket manifolds and rails aren't that expensive.
GPM is offline
Old 09-30-2014 | 09:33 PM
  #36
I like the full EZ EFI 2.0 FAST kit, but I don't like the 4 barrel style TB for boost.
Old 09-30-2014 | 10:11 PM
  #37
GPM
You can use a Fast, Holley, Edelbrock , Accel, whatever manifold with injectors and rails, the Fast 1375 throttle body and the fast XFI 2.0 with self tune.
GPM is offline
Old 10-01-2014 | 02:47 AM
  #38
Just go roots and dual carbs. Easy and reliable or call whipple and get the whole kit.
Crude Intentions is offline
Old 10-01-2014 | 03:47 AM
  #39
I am not doing a roots. I am doing a custom turbo set-up and need a throttle body like OEM.
Old 10-01-2014 | 08:09 AM
  #40
the factory manifold is not going to handle the airflow to make the power you are going after..not even close, a few have spend tons of hours / $$ on making them work ok, think of it like this just put a std performer oval port intake on your engine and then try to make 600+hp...you can ck with artifriends on here he will enlighten you on those intakes..but if you insist go on with your bad self...
