efi vr carb
Old 08-10-2014 | 01:55 PM
Default efi vr carb
We took our baja with a new 540 to be tunned
The shop is telling us to dump the efi and put on a carb. they feel one side of the moter is running rough and tell us a carb will take care of it. The shop sayes they can go ahead with the efi but it will cost alot more. I feel like im taking a step backward Does any one have any imput.
krplct6 is offline
Old 08-10-2014 | 02:15 PM
carb is ok but I would stick with the EFI
get another shop to fix your boat,whats next point ignition?
boatnt is offline
Old 08-10-2014 | 02:30 PM
GPM
Sounds like you went to the wrong place.
GPM is offline
Old 08-10-2014 | 06:30 PM
yschmidt's Avatar
I went from carbs to efi and I would never go back.
yschmidt is offline
Old 08-10-2014 | 06:32 PM
what EFI system ? if you are trying to get a factory merc unit to work with a 540 going to get $$$$$$$$ aftermarket EFI will be much better, but cost wise the carb is going to be much cheaper..
ezstriper is offline
Old 08-10-2014 | 09:30 PM
The systems from FAST aren't terribly expensive. Seems like about 4k would do a 540.
...unless I overlooked something?
Cole2534 is offline
Old 08-11-2014 | 01:35 PM
depends on what you can spend...can get a nice carb/intake for a grand or so....so 4k for EFI...3k can by a lot of fuel
Old 08-11-2014 | 01:50 PM
Rookie's Avatar
Less, about $2600
http://www.offshoreonly.com/forums/g...mable-efi.html
Rookie is offline
Old 08-11-2014 | 01:58 PM
SB
The fuel system that the owner or owner's repair shop can tune correctly is the right choice.
If you can't tune what you have, either learn or switch.
Obviously, you can switch shop's too.
SB is offline
Old 08-11-2014 | 03:45 PM
GPM
Find someone that can actually tune what you have, or run your current efi setup, intake, throttle body, injectors, rails, sensors, ect, with either the Fast or Holley self tune ECM and harness.
GPM is offline
