496 Stroker/Dart Pro1 Heads >
Old 08-28-2002 | 07:02 PM
StrikinLightnin's Avatar
Question 496 Stroker/Dart Pro1 Heads
Anyone running Dart Pro1 Heads?
I'm thinking about putting them on my 454s +30over
310cc intake/119cc chamber
2.25/1.88valves
I'm toying with the thought of turning my engines into 496 strokers.
Presently 5.88/6.10 112centerline roller cam
Anyone have experience with either Pro1 heads or 496 strokers?
Dennis
StrikinLightnin is offline
Old 08-28-2002 | 07:22 PM
The stock heads on a 454Mag flow pleanty for a 454ci motor...you won't see much there in power gains unless your raising your cr to like 9:1 with the alum. Darts.
What exhaust system are you running now?
Back4More is offline
Old 08-28-2002 | 08:23 PM
Back4More,
The compression ratio presently is 9.6:1 with TRW'S
Since I droped a valve at the C.O.PS. run I want to go with 9.6:1 SRP piston's with a quarter stroke crank aka:496ci
Intake is a Victor JR./1" spacer with a Nickerson 960 on it.
Exhaust is Stainless Marine.
Dennis
Old 08-28-2002 | 08:56 PM
The WETTE VETTE has a 13.2:1 compression 496" Chev. with fully ported 325 Pro 1 Darts. It also has a stage 5 Nickerson 1050 Dominator, CMI exh, Merlin intake, full MSD, and a Comp solid roller cam 272/280 @ .050 with .714" lift. It runs pretty good. The stroker crank with 6.385" rods and the appropriate pistons results in a very good torque motor that works well in boats. Take a ride to LaPorte sometime and check it out.
WETTE VETTE is offline
Old 08-28-2002 | 10:24 PM
KAAMA's Avatar
35Lightening,
If Pro-1's are what you want then you should go with the 310cc head that Dart offers in the Pro-1------Do NOT go any larger! I run the 310's on my 540's.
KAAMA is offline
Old 08-28-2002 | 10:42 PM
35lightning,
Dan was saying it might have been a rocker or something at the lunch stop...sorry to hear it wasn't.
Maybe Bruce at Wolffie's could set you up.
Old 08-29-2002 | 10:23 AM
pachangalpina's Avatar
My engine is currently on the dyno and is very close to what you are talking about. 454 @ 60 over 4.25 stroke w/6.385 rod = 496ci. I have the Dart Pro1 heads that have been worked to remove casting flash without enlarging the ports. I am using JE/SRP pistons for a compression ratio of 10.1 to 1. I am using the 731 crane cam which I don't remember the specs on at the moment. Those are the main features of the long block but a lot of other little things have been done. I am using the Arizona Speed & Marine EFI which is like the HP500efi but I am using larger injectors and throttle body. We are still making adjustments but prelim. #'s on dyno are: 590ft/lbs @ 3800rpm and the torque doesn't really drop until about 5400rpm (560ft/lbs). This is all designed to work with 92 oct. pump gas.
Todd
pachangalpina is offline
Old 08-29-2002 | 04:06 PM
Default KAAMA
Do you think my boat would be faster with 310's or the 325's that I am running. I have seen 97.8 MPH at 6300 RPM for a best GPS top speed turning a 29 pitch Spinelli through 1.5 gears. I like this subject and want everyone's opinion. Oh ya the throttle response and acceleration are pretty awesome the way the motor is set up now.
Old 08-29-2002 | 07:27 PM
Back4More,
I was at the marina pulling off the other head and I had a conversation with a friend that's into cars.
He suggested Bruce Wolff in New Buffalo for my machine work.
I believe that KAAMA had given me Wolff's phone number in a previous post....Thanx
Dennis
Old 08-29-2002 | 07:43 PM
panchangalpina,
My cam is a crane 139631.
I think the 731 is close to what I'm running.
I spoke to a shop today that suggested that I use SRP
pistion #142991 which is a dome 10.2:1 at 118cc
I would like to be at 9.6:1 - 9.5:1
They suggested to go to a .051 head gasket which would bring me to 9.7:1
Then take some off of the dome to bring me down to 9.6:1
OR use a .039 head gasket and take more off of the dome.
Is either of these a commom practice?
