Gen6 cylinder bore question max bore? >
Old 10-08-2014 | 09:28 AM
Full Force's Avatar
So in a nutshell I should be fine cleaning them up and going bigger if needed as long as the material is there, and keep them as close as possible and not go bigger then needed. Right?
Full Force is offline
Old 10-08-2014 | 09:34 AM
rmbuilder's Avatar
MarineKinetics
Tim,
I would consider a sonic test mandatory prior to investing any resources into your OEM block. With that considered, at your output levels, main saddle integrity,as well as the wall stability is a primary consideration. I would suggest there is more value in selling your OEM cases and applying those assets to a dedicated aftermarket block than investing into a production item.
Below is an example Gen VI test.
Bob
[ATTACH=CONFIG]530621[/ATTACH]
File Type: pdf
rmbuilder is offline
Old 10-08-2014 | 09:37 AM
I have a GEN V at 4.565 with a custom set of Diamond Pistons. The Diamonds didn't take too long to get. My machinist double checked everything and felt very comfortable at that bore even knowing how hard I would push the motor.
ThisIsLivin is offline
Old 10-08-2014 | 09:46 AM
Full Force's Avatar
Originally Posted by rmbuilder
Tim,
Bob
thats kinda my thoughts also, wondering what I can get for mine used? I can buy new ones easier if I sell mine off, especially knowing the same machining is needed anyway using mine it new..
Btw we will be talking cams after first of the year also... After I recover from surgery lol
Old 10-08-2014 | 09:50 AM
vintage chromoly's Avatar
Originally Posted by Full Force
Ray says that if there's enough material there it's not going to be an issue if there is it that I need to buy blocks simple as that I was just trying to get more opinions
I hear ya. I was mistaken in thinking the aftermarket blocks were more finished than they are.
vintage chromoly is offline
Old 10-08-2014 | 09:51 AM
Full Force's Avatar
Gotcha.. Yea they need made perfect also
Old 10-08-2014 | 10:02 AM
Tim, good luck with the surgery. I know as of a few years ago, recovery from a full replacement was actually faster than a repair. PT should have you up and starting to move within 48~72 hours. Those pt people though, they are a sadistic bunch and take great joy in making full grown manly men whimper like biitches... you have been warned...
phragle is offline
Old 10-08-2014 | 10:03 AM
Full Force's Avatar
Thx Rob and lol shoot me now haha
Old 10-09-2014 | 05:24 AM
Full Force's Avatar
Well, after lots of thinking and some talking with a few guys, however I can probably use my stock GM blocks I am going to buy new blocks...then I don't have to worry about anything, I do not wanna put myself in a position for issues long term, and If I max them out now that leaves me no room for a possible problem later...
Thanks for the advice guys...!
Old 10-09-2014 | 05:36 AM
Good move Tim!
