motor oils prefered on performance boats >
Old 10-28-2014 | 11:26 AM
  #141
Originally Posted by SB
Yes sir.
Maybe some sensors on the underside of the pistons would be cool. Espcially for the SC and Turbocharged crowd.
Anyone smell burnt oil after a hard run ? This can sometimes be from an underisable tune and the pistons getting too hot. The oil splash that hits this area will then get superheated.
I'm with you. Usually have Burt oil stains on the bottom of the pistons when detonation has happened.
Black Baja is offline
Old 10-28-2014 | 11:27 AM
  #142
vintage chromoly's Avatar
Originally Posted by benjen
That's really not the right place for a temp. gauge. The pan is the coolest place the oil is going to be!
Here we go.
vintage chromoly is offline
Old 10-28-2014 | 11:56 AM
  #143
SB
I'm pretty sure about it. Doesn't the oil return to the pan after the oil coolers?
No.
Most are set up this way:
Oil from pan to oil pump to remote filter to oil cooler back into block and then throught out it's journey thru block/crank/cam/etc....all to mostly drain back to pan and get beat up by crank/etc.
SB is offline
Old 10-28-2014 | 12:01 PM
  #144
Originally Posted by Black Baja
Are you sure about that?
benjen is offline
Old 10-28-2014 | 12:05 PM
  #145
As SB said the only thing that fills the pan with oil is gravity and possibly right out of the oil pump but that's getting a little advanced for this reply.
Old 10-28-2014 | 12:10 PM
  #146
Side clearance from the rods mostly. And mains and some out of lifters. Drains to the pan and starts all over again.
fbc25el is offline
Old 10-28-2014 | 12:19 PM
  #147
Holy cow!
Old 10-28-2014 | 12:21 PM
  #148
SB
How did I answer his post before his post posted ?
Wholly f*k I'm fast !!!!!!!
LMAOF !!!!
SB is offline
Old 10-28-2014 | 12:41 PM
  #149
LMAOF !!!!
That's what she's been trying to tell you.
Old 10-28-2014 | 01:00 PM
  #150
SB
Exactly, but I'm done and gone before that remotely happens.
So fast, it's like nothing ever happens.
LOL.
SB is offline
