motor oils prefered on performance boats
#131
1) Morel's tick for a little bit anyway.
2) High lift with relatively short duration .050" HR's (especially with Roller Rockers) tick for a bit anyway.
3) Many aftermarket rocker covers are noiser.
Still, I prefer the multi weight. Flows a little faster when cool.
I have a 218/224 at .050" .570" lift HR (yeh, that's a little hard on the valvetrain) in my current small block. Hell yeah they tick for a bit...with multi weight...when cold. However, when 80+ out and water temp well into the 70's...it doesn't do it much at all.
PS: I run a plugged oil filter pad bypass too.
Warm up is crucial with these motors.
Black Baja's method/reason for changing oil types/weight is how I do things too. Without going overboard on weight. IE: going to a heavy straightweight.
Back to Darrin Morgan's saying: "Your motor is telling you what it want's, are you listening ?"
#132
Something i think of substantial value that we can take from this thread is the importance of an oil temp gauge. Being from Ohio and boating in relatively cold water, I too, experienced long warmup times with my small block on my old boat. Before I installed the oil temp gauge I had a tendency to throttle up before I should have.
Pretty easy to tig a bung in the pan and watch the temp.
#134
#135
It's the hottest place. My stock Mercury pan has a bung in it for a temp sender. The only thing that might heat the oil after the pan is the oil pump. Everything after that is lines filter and cooler.
#137
Hottest place, or that we care about, is at the bearings.
Next time I install bearings, I get some with a temp probe built in to them.
Oh boy, oil discussions always get fuked up. And then oil temp sender location discussions egt f*ked up some too.
Some like temp before the cooler, some after the cooler, some in the pan, and etc......
#138
#140
Yes sir.
Maybe some sensors on the underside of the pistons would be cool. Espcially for the SC and Turbocharged crowd.
Anyone smell burnt oil after a hard run ? This can sometimes be from an underisable tune and the pistons getting too hot. The oil splash that hits this area will then get superheated.
