Oil restrictor size hp500 >
Old 11-11-2014 | 10:27 PM
  #51
Originally Posted by SB
Holy Schit !
Everyone else run this high ?
I think this would be a good poll. I'd like to see if I run a lot less than everyone else. I could be way off from the norm but never seen any issues. I've never run more than 80psi on anything even under full steam. Mid 7000rpm's even, That was not a boat though.
Yikes. Especially those idle pressures. Did I say 'Holy Schit' yet ?
Nothing I've ever been in has ran that kinda pressure hot. Every black motor I've ever seen has been in the 40 psi range idling.
Rbesola is offline
Old 11-11-2014 | 10:48 PM
  #52
Holy Schit !
Mine are 90ish cold at 3000rpm. Once warmed up around 75psi at 3000-WOT.. Hot idle, about 50-55psi. After an extremely hard run, they may dip into the 40's while in gear at idle. Soon as i pull out of gear theyll sit at 50-55psi.
MILD THUNDER is offline
Old 11-11-2014 | 10:56 PM
  #53
For what its worth every boat I`ve had the oil pressure dropped quite a bit after a hard run, my current motors set off my 20psi warning lights.
K&N breathers always leaked oil, thought my answer was the baffled Teague breathers , still leave a mess, I currently have socks over em.
I tapped my oil fill and ran a line to the flame arrestor that seemed to help quite a bit. If I were to do it all over I`d run overflow tanks.
Then again its all a band aid for bad machining and blowby.
Your foaming oil is probably the same condensation I get under the valve covers near the front.
That`s what I get for buying a heavy old Cig. If it were an awesome Fountain the load on the motors would probably be half and all them problems would be solved.
ICDEDPPL is offline
Old 11-11-2014 | 10:58 PM
  #54
Rule of thumb. And mercury racing rule. 10lbs per 1000rpm is all that is needed. Anything else is a problem. Foaming or locked up in the heads. That is the rule. This is for a engine at temp
Drew555 is offline
Old 11-11-2014 | 10:59 PM
  #55
Change the spring in your oil pump(s)
Drew555 is offline
Old 11-11-2014 | 11:22 PM
  #56
HV Pumps?
Black Baja is offline
Old 11-11-2014 | 11:27 PM
  #57
Originally Posted by Black Baja
HV Pumps?
Na, standard pumps shimmed.
Old 11-11-2014 | 11:39 PM
  #58
I can understand the pressure drops in that case but in the op's case it should not be dropping the way it is with a HV pump...
Old 11-12-2014 | 01:52 AM
  #59
Basically all of the exact symptoms my motors have, I guess I'm overthinking the whole situation.
Rbesola is offline
Old 11-12-2014 | 05:50 AM
  #60
OK, I know SB will find a way to bust my balls, (he has a knack for that ), but I'll toss in my observations with my engine. Admittedly, I'm running a lighter oil than most of you (15W40 currently), and I am running the HV 10778C Melling pump. I usually see around 65 - 70 at idle cold, and around the same at speed. After a hard run it will drop down between 25 - 30 PSI when I pull the throttle back at idle. Blip the throttle and it will immediately jump up to 45 - 50 PSI.
If I was seeing 90 PSI I would be afraid of blowing the cover off of the oil filter!
Budman II is offline
