EFI intake
Old 11-26-2014 | 01:23 PM
Originally Posted by mike tkach
that is a nice looking intake.for some reason i thought you had oval port heads
I do have large ovals and the mismatch is minimal because they are more of a roval shape.
Tinkerer- Missed the tall deck. I don't think they offer the pro FLO xt in a 10.2 configuration. Edelbrock discontinued the oval version of this because the two rear banks has distribution issues. The design of the rectangle port intake is different and wasn't affected. I spoke with several guys including Haxby about my setup and it was deemed a non issue. Try calling tech at edelbrock to see if they offer this in the 10.2 configuration. Sometimes they have as cast intakes for sale. I almost bought one to have Wilson port and finish before realizing that was a HUGE waste. Good luck!
Borgie is offline
Old 11-26-2014 | 08:35 PM
Borgie, Do you happen to have the height measurement of your Pro Flo manifold from the bottom flat surface to the top? Im looking for a similar setup but can only go so high. Thanks!
Fordtrucks is offline
Old 11-26-2014 | 08:56 PM
9.9-10"?
Old 11-26-2014 | 10:22 PM
If you can wait until this Friday, I will be back home and can check it when I arrive.
Borgie is offline
Old 11-27-2014 | 12:34 AM
BUP
Total height is 10 ".
BUP is offline
Old 11-27-2014 | 06:14 AM
Perfect, thanks!
Old 11-27-2014 | 08:55 AM
http://www.jegs.com/photos/300/350/3...arentPhoto.jpg
HaxbySpeed is offline
Old 11-27-2014 | 09:00 AM
Thanks guys. My stock mpi 502 intake is 11 inches tall so this should fit no problem!
Haxby, I sent you a PM about EFI. Get back to me when you can. Thanks
Old 11-27-2014 | 11:39 AM
Originally Posted by Borgie
As mentioned above, Edelbrock makes a very capable tunnel ram(Pro Flo Xt) intake that utilizes a LS throttle body. Would easily handle your goals HP wise. This is one I just picked up.
I've looked at those alot. I really dig that manifold setup!
As far as the port match from the rectangle to roval, how significant is the mismatch? Do you have a pic with the intake mocked up?
MILD THUNDER is online now
Old 11-27-2014 | 04:08 PM
BUP
www.precision-metalcraft.com
Posted this here before but will say a friend of mine had a bunch of time testing manifoilds and ended up using this for the Amsoil Engine Masters on his Pontiac. IMO very sharp looking as well.
.http://performancedesign.com/product/carbon-tr
BUP is offline
