Going blown have a few questions? >
Old 12-22-2014 | 09:48 AM
imo,to make almost 1000hp with a non innercooled 540 with a 8.71 can be done on the dyno for 8 seconds but put it in the boat and it will be all over in no time flat.i sure would like to see the dyno sheet,espically the boost chart.
mike tkach is offline
Old 12-22-2014 | 10:14 AM
I think it could be done but your gonna have to spend some money on parts. It will have to be carefully planned out to get there. Will it live? Maybe. I can assure you if you get one bad tank of fuel its done.
Black Baja is offline
Old 12-22-2014 | 08:42 PM
All these claims I read wear me out,dynos are great but real world on the water full throttle negate a lot of these inflated claims..just do your homework,because you just spent a ton of money on your pride and joys
proboat-wes is offline
Old 12-23-2014 | 06:42 PM
T-Mone's Avatar
T-Mone
Ok engine is a dart big m block brodix cnc heads solid roller bullet cam 871 blower shop fully cnc intake. 2 750 carbs. motor w 6lbs an 34* timing on 93 made shy of 1000. We detuned to 5lbs an 29* timing motor made 909 at 6300 906 at 6000. thats the way its going in boat.
T-Mone is offline
Old 12-23-2014 | 07:02 PM
rmbuilder's Avatar
MarineKinetics
T-Mone,
I would suggest to you that a marginal reduction in boost of 1psi may be perceived as a durability asset long term. However a timing reduction from 34º to 29º may end in the liability column.
Bob
rmbuilder is offline
Old 12-23-2014 | 07:33 PM
T-Mone's Avatar
T-Mone
I value everyone's opinion. Rich is a good friend of mine I trust his decisions.
Ron
T-Mone is offline
Old 12-23-2014 | 08:22 PM
How long ago was that motor done? Didn't Zul sell his shop over a year ago?
Unlimited jd is offline
Old 12-23-2014 | 08:30 PM
T-Mone's Avatar
T-Mone
last week.Like i said rich is a personal friend of mine
T-Mone is offline
Old 12-23-2014 | 08:38 PM
proof is in the dyno sheet,why not post it for us to see?
Old 12-23-2014 | 08:44 PM
These are the forum conversations that drive a person bonkers!
