Pushrods
Old 01-19-2015 | 07:55 AM
rmbuilder's Avatar
MarineKinetics
Default Pr
VC,
When approaching the optimal pushrod selection it is beneficial to approach the pushrod as a subsystem of the valve train rather than a standalone component. As always in the valve train, the clash of mass versus stiffness comes into play. A few general rules to think about;
Shorter is always better within the correct geometry. The buckling stiffness is inversely proportional to the square of the length of the column. For example, a 2.0” reduction in the length of a 12” pushrod would, for the same cross-sectional area, increase the critical load by a factor of 1.44.” (Thanks to Jack Kane for that math)
The key is to control the dynamic mass of the system while minimizing compliance in the pushrod. The additional PR length required in a tall deck application is a definite negative. Column width trumps wall thickness, however when you run out of real estate on diameter you can only move inward toward wall thickness.
In regards to the balance of mass versus stiffness in your pushrod selection, if you error off the optimal balance, you would always be best served to err on the side of increased stiffness with a slight mass penalty over less stiffness and increase compliance in the pushrod side of the system.
Bob
rmbuilder is offline
Old 01-19-2015 | 08:12 AM
vintage chromoly's Avatar
Originally Posted by ezstriper
ask Bob to send you a push rod length checker, the ck your setup...get the right ones from Bob..
We have adjustable "measuring" pushrods.
We're going to call bob and ask his advice.
Just thought that maybe there were general parameters in a chart from or the like.
Thanks for all the replies fellas.
vintage chromoly is offline
Old 01-19-2015 | 08:15 AM
Originally Posted by rmbuilder
VC,
When approaching the optimal pushrod selection is beneficial to approach the pushrod is a subsystem of the valve train rather than a standalone component. As always in the valve train, the clash of mass versus stiffness comes into play. A few general rules to think about;
Bob
Thanks for the reply bob.
