Ring end gaps >
Ring end gaps
Ring end gaps
Old 02-24-2015 | 10:41 AM
  #51
Originally Posted by brian41
I have never seen an engine COME from the 3 I listed without a circulating pump. We did testing with crossovers using temp sensors on the blocks 20 years ago in real world conditions (out on the water in a boat). Shortly after I sent back all the crossover systems and have run circulating pumps on EVERYTHING I have built since. You would chit yourself if you did the same tests. There is a lot to be said about even engine temps not to mention it allows you to build a tighter tolerance engine that lasts longer. We are currently spending a ton designing a dry sump serpentine belt that uses a circulating pump for the engines we build. In the past we have altered the old Merc efi system to work but we are looking for something better.
Agreed!!! and I am also an advocate for closed cooling as that is hands down the best way to go for certain applications
adk61 is offline
  #52
900sc mercury
MILD THUNDER is offline
Old 02-24-2015 | 10:49 AM
  #53
Originally Posted by SB
I thought this was finally debunked in an infinate cooling supply system. IE: open system.
The faster the water flows, the more it will cool.
Just like air temp, add in some wind and heat is removed quicker.
Thus us in the North really only care about the Wind Chill index vs the actual air temp index.
Again, this is for open cooling systems. Not closed cooling.
we need more temp in the engine, not less... so yes in your statement you'd be correct in open cooling, but in most High HP conditions dual stage and bigger pumps supply an infinite supply of water... thus making it difficult to achieve a desirable temp... so again balance is the key... holding water in block long enough to effectively cool and at same time maintain an optimal operating temp ... this is my point, otherwise water temps will be all over the map and not nearly consistent in all areas of the block and heads...
adk61 is offline
Old 02-24-2015 | 10:51 AM
  #54
but really... what do I know, I'm just a silly crazy Canuck!! lol
adk61 is offline
Old 02-24-2015 | 11:01 AM
  #55
Can you squeeze a p/s pump on that setup?
Black Baja is offline
Old 02-24-2015 | 11:11 AM
  #56
Originally Posted by mike tkach
it has been proven that that is incorrect.it is true in a radiator taking heat out and transfering it to the air.the more cool water you can pass through the block the more heat will be transfered to that cooling water.i,m net being a dik either,just stating facts.
This engineer agrees with you. That's simply not how an open cooling loop (or infinitely large closed loop, but I digress) works.
I thought this was finally debunked in an infinite cooling supply system. IE: open system.
Fitting example right now being in the very NE.
That's correct, SB. A and Delta T are the primary considerations in heat transfer.
Cole2534 is offline
Old 02-24-2015 | 11:22 AM
  #57
SB
I was answering your present statement at the time, not the future one's.
Carry on.
SB is offline
Old 02-24-2015 | 11:31 AM
  #58
Yes but its old school and could be cleaned up. We can currently get a system from the automotive world that will work but it uses 3 accessory belts plus the dry sump belt. We are working on a 2 belt system.
brian41 is offline
Old 02-24-2015 | 11:41 AM
  #59
agreed.. Mike I kinda derailed myself here cause I was thinking about something I've encountered with mine... in that a 2 stage pump running all in and all out isn't making "MY" 1100s run hot enough, slowing the flow down with use of some restriction achieved this and also increased my system pressure as well...
adk61 is offline
Old 02-24-2015 | 11:47 AM
  #60
My new engine has a crossover without a bypass. However, I'm not sure it will stay that way.
Brian could you elaborate on your testing? Did the crossovers you used have bypasses with thermostats, or were they just a crossover?
With unlimited cooling water routed through a single pass exchanger (block/heads/etc) and no control the engine will NOT be a uniform temp. It's simply the physics of heat transfer that the exiting water will be warmer than the entering water and the block's temp will vary in accordance. Now add in a thermostat, and it gets much better. I'm not convinced the thermostat temp really even matters, so long as it's a constant temp, all else can be allowed for.
Cole2534 is offline
