What's wrong with AFR's exhaust port? >
Old 05-25-2015 | 05:59 PM
  #221
Full Force's Avatar
Originally Posted by SB
Exhaust valve 100 times more common to seize than intake...or more.
You ever find out what caused the 1/4" or more clearance from dist to dist pad on intake ? Reason for asking I never heard if you checked intake port flange to see if a bunch of material was milled off from last build....or deck was cut considerably....or ?
You ever check lifter bore to lifter clearance ?
How did you determine pushrod length ? Any pics of the rockers installed ?
Intakes were milled issues fixed with a .120 gasket...
Lifter bores .0012-.0015 on starboard, .0018-.0020 port engine bob m and Johnson both said .0012 -.0015 ok and was told "sweet spot" for them..
Pushrod length done half lift met kind I will see for pics... 5 people said I was ok there
I get many things can happen but this is not right I am lost but I don't see any sign at all of detonation here
Full Force is offline
  #222
Full Force's Avatar
Guide could be trashed now from the trama anyway. So, I don't think checking the guide vs valve right now would show accurate results.
It does with cylinder that was not damaged....
Old 05-25-2015 | 06:01 PM
  #223
SB
That will just show that valve with that gude.
Make sure to put some lube on the valve that won't burn off at 400F when you check it.
SB is offline
Old 05-25-2015 | 06:20 PM
  #224
Tim, I would bring the heads to your machine shop. Have them check the guide clearances. Also, I'd have them check the SEAT WIDTHS. In marine applications, you want a nice wide seat margin to aid in cooling the valves.
Theres a reason Teague marine machines their AFR heads before they sell them. You pay a little extra for it, but they aren't out of the box car heads, mass assembled, with inconel valves thrown in and called "marine" heads.
Although, I will say, in AFR"s defense, they specifically told me in an email regarding a marine application, that for marine and boosted applications, that it is the engine builders responsibility to size the guides accordingly. Here is the email from them
Joe,
Based on the engine combination, power range and Marine application, you should look at our 305 Magnum heads. Our 305 head is designed to generate optimal airflow translating to stout horsepower, torque and throttle response specific to your application.
You will need to special order your heads with our #8002 “spring exchange” to suit your hydraulic/roller camshaft.
Note: We do not size our valve guides specific to Marine/boost usage. It is the engine builders’ responsibility to check for correct guide clearance per their Marine/boost application. We recommend that you special order your heads with an “Inconel” exhaust valve upgrade, better suited to marine exhaust temperatures and the possibility of exhaust reversion.
Hope this helps. Please call if you have questions or require further assistance with your order.
Rob Wood
Air Flow Research
661-257-8124 ext.123
[email protected]
MILD THUNDER is offline
Old 05-25-2015 | 06:35 PM
  #225
Tim , how did the oil look ? An excessively tight guide and even a little moisture in the oil will gall and weld the valve to the guide . Dont ask me how I know........ Good luck , you'll get to the bottom of it !
PARASAIL941 is offline
Old 05-25-2015 | 06:47 PM
  #226
donzi matt's Avatar
You never answered my question - one wideband per motor or two? And if one was it on the side of the motor that let go? I keep going back to the previously milled intakes. Are you sure they were flat milled and not angle milled? I'm not trying to point the finger at you at all, but you still have one motor that hasn't lynched, so getting to the root cause of why this one let go is imperative. As far as I know the only thing reused on these motors were the intakes. I still think the fact you dropped an intake valve instead of an exhaust valve points away from tight guides short of a quality control issue. 10 seconds at close to peak cylinder pressure before it let go really sounds an awful lot like detonation.
donzi matt is offline
Old 05-25-2015 | 06:49 PM
  #227
Full Force's Avatar
Joe,
Rob Wood
Air Flow Research
[email protected]
I cannot afford to have 2000.00 in work done to new heads right now, if I find out that all this is wrong and not marine spec, there are gonna be some serious issues, fuk me for trusting..... I am so close to selling stuff and buying 420's drop in garbage and run the boat
Old 05-25-2015 | 06:51 PM
  #228
Full Force's Avatar
wideband on one side each engine, same side that broke, the intakes are same both engine gaskets were 100% sealed, this is NOT detonation related, I would have signs of melting on plugs, eyebrows of pistons.... I do not... I didnt drop a valve I broke a valve, I can't get heads to machinist tonight or I would....
Old 05-25-2015 | 06:52 PM
  #229
Full Force, I would recommend starting a new thread pertaining to your issues. Others might be better able to offer help, and hopefully your post-mortem on your engine will reveal the issue and help others avoid the same thing. I'm very sorry to hear about your bad luck! Hopefully you will be able to find the cause and get this motor back in action soon to salvage the season. I sure hope it's an isolated problem and the other engine does not have a similar issue. Good luck with it!
Budman II is offline
Old 05-25-2015 | 07:14 PM
  #230
Tim, did you have 4-7 swap cams?
Black Baja is offline
