What's wrong with AFR's exhaust port? >
Old 05-25-2015 | 09:05 PM
  #241
donzi matt's Avatar
Originally Posted by Black Baja
Then 4-2 fire next to each other...
If he got the cams from Bob, typically he uses the 8.1 cores and the firing order is 1-8-7-2-6-5-4-3, at least they were on mine. Tim can verify this if the cam gear retaining bolts are metric threads.
donzi matt is offline
Old 05-25-2015 | 09:15 PM
  #242
Full Force's Avatar
yes thats firing order
Full Force is offline
Old 05-25-2015 | 09:19 PM
  #243
Rookie's Avatar
Are you running water cross overs and are the back of your intakes plumbed to dump water out of them? This helps propagate flow through the back of the head. I seized valve #8 3 times within 15 seconds after getting on plane. My guides were checked and honed over and over and they still failed.
Rookie is offline
Old 05-25-2015 | 09:21 PM
  #244
Originally Posted by Rookie
Are you running water cross overs and are the back of your intakes plumbed to dump water out of them? This helps propagate flow through the back of the head. I seized valves 6&8 3 times within 15 seconds after getting on plane. My guides were checked and honed over and over and they still failed.
Rook, looks like this happened with #2, which should get excellent water flow being on the front of the engine.
Budman II is offline
Old 05-25-2015 | 09:24 PM
  #245
the firing order had no bearing on this failure.tim,s new wires did not cross fire.maybe lightning struck the nearby water and caused the failure by overheating the water.
mike tkach is offline
  #246
Full Force's Avatar
Are you running water cross overs and are the back of your intakes plumbed to dump water out of them? This helps propagate flow through the back of the head. I seized valves 8 3 times within 15 seconds after getting on plane. My guides were checked and honed over and over and they still failed.
I am running the same setp I have had for 10 years with 3 different engines with zero issues.... I did not change what woked fine....
Old 05-25-2015 | 09:26 PM
  #247
Full Force's Avatar
It could be as simple as a bad day at the afr plant, or lifter plant one of the 2 seem to be the cause because nothing else adds up...
Old 05-25-2015 | 09:30 PM
  #248
SB
I thought I was the only one that happened to. At first, I thought the burn marks on the bottom of my boat was from going to fast.
SB is offline
Old 05-25-2015 | 09:31 PM
  #249
Rookie's Avatar
Oh my fault, I thought you rebuilt these engines with new aftermarket heads...
These are not the old engines out of the Scarab III?
Rookie is offline
Old 05-25-2015 | 09:32 PM
  #250
Full Force's Avatar
Yes I did, so why did I not fuk up my chitty pro comps? Hmmmm
