Intake Manifold Gaskets
I have never seen a intake for a BBC that wasn't blocked off in the back... If you know of one... can you show me it? Or tell what they used them on. That would be a new one on me. I always drill and tap back there for water pressure sender, and have done both sides back there for steam pocket bleed offs.
My buddy just went through this where the salt had actually seaped through the gasket and started corroding the intake. When he put it back together his mechanic suggested they use the gasket that blocked it off and also epoxy painted the intake to provide further protection...
Edit in: I see you mod your intakes for this too.
There's some intakes with threaded in ports just over these cyl head rear coolant ports so you can run water lines back to the t-stat housing. Some come with bosses you must drill and tap to do this. Some don't have the option at all.
Here's one intake with the drilled/tapped bosses (from the manufacturer) for rear water outlet.
And another:
Anybody use these gaskets from Flat Out gaskets yet ?
It's about time someone makes modern type gaskets for the SBC and BBC !
Full PDF catalog for all their stuff: https://www.flatoutgroup.com/docs/20...alog-Cover.pdf
