Carb opinions 540's 700 hp... >
Old 05-08-2015 | 09:13 AM
  #321
mercury marine sold a ton of marine engines with quadrajet 4 bbl carbs.these carbs are designated as marine carbs.do they have j tubes or sealed throttle shafts?
mike tkach is offline
Old 05-08-2015 | 10:01 AM
  #322
No, but they are black...
Black Baja is offline
Old 05-08-2015 | 10:43 AM
  #323
that really helps!
Old 05-08-2015 | 11:02 AM
  #324
I can't remember if it was Quickfuel or Holley posted some literature the the black anodizing on the carb actually showed a small increase in power. I know it's kinda off track to the discussion but I thought it was an interesting piece of information.
Old 05-08-2015 | 11:12 AM
  #325
SB
I tried all sorts of coatings, including teflon based, and etc, etc and I found no power with throttle bodies.
HArd anodizing in carbs, though, make perfect sense ! Anything to keep electrolysis and other schit out of carbs is well worth it.
SB is offline
Old 05-08-2015 | 11:16 AM
  #326
That's why there is NO Polished Aluminum on these new motors! I even Black Anodized the alum timing covers!
TAStevens is offline
Old 05-08-2015 | 03:19 PM
  #327
You can get the fast dual channel wideband with 22ft, 12ft, or 6ft cable
Attached Thumbnails Carb opinions 540's 700 hp...-screenshot_2015-05-08-15-18-49.jpg
MILD THUNDER is offline
Old 05-08-2015 | 08:57 PM
  #328
that reminds me of a guy who told me his engine ran seven degrees cooler after he painted it black.it never ceases to amaze me some of the bs guy,s come up with.
Old 05-08-2015 | 09:10 PM
  #329
Quickfuel claims 6 degree drop in fuel temperature with black diamond coating.
Old 05-08-2015 | 09:33 PM
  #330
SB
I can make any carb run twice as cool or more...for free. Drive around heat soaking the engine and the put the fking hammer down for 5-10 minutes or more. LOL.
All that fuel flow and air flow will drop it right down.
On a more serious note, can't dispute what QF says unless tested, bu he 6*F is no big deal. Big deal to me would be extra protection to possible junk and electroysis happening inside carb while sitting for a bit.
SB is offline
