Carb opinions 540's 700 hp... >
Old 05-05-2015 | 06:17 PM
  #301
PM me what you paid...if you want?
TAStevens is offline
Old 05-05-2015 | 07:58 PM
  #302
KAAMA's Avatar
Originally Posted by Full Force
I am doing 540's afr 325 cc heads bob m cams nearly every person said to see 700 hp I need Dominators and that is my plan but what might be easier option if height is issue? I cannot go higher then my 4150's are now...
Just wanted to see combos and if using Dominators what kinda jetting to start with ...
Dave Wesseldyk just assembled and dyno tested a 540cid marine Chevy with the stock rectangle port cast iron heads and small 250 (B&M???) supercharger with a Bob Madara hydraulic cam/lifters, and it made 800 lbs of torque @3500rpm and 700hp @ only 5300rpm with only about 4.5 lbs of boost----and it only had a pair of Holley 600cfm carbs!
I remember Dave was pretty interested in how those stock, little gooner 600 carbs would work on this supercharged 540cid he was building for this customer. The engine used to be a 509cid and the customer didn't want to buy new carbs and didn't want to make too much HP with the Bravo One drive. Dave said the rev limiter was set @5400rpm...so, he didn't take it any further than that.
You can call Dave and ask him yourself
KAAMA is offline
Old 05-05-2015 | 08:18 PM
  #303
Full Force's Avatar
Forced air is a totally different animal....
Full Force is offline
Old 05-05-2015 | 08:25 PM
  #304
Sounds about right. Mike Tkach recently did a 460CI with a 177 blower and a single 1025 Carb, made 691HP at 4.5LBS of boost. Another buddy of mine had a 509, with 250 B&M, iron heads, made 700HP with a single dominator.
What i have seen, is, on roots blowers, IF the carbs are a restriction, you can lose boost. I've seen guys swap out small carbs for bigger carbs, and gain a significant amount of boost. Lets say a guy had 5lbs of boost with a pair of 750's, and he bolted on a pair of 950's, and now had 7lbs of boost with no pulley changes...... He could slow the blower down, to get back to 5lbs of boost, and have a cooler air charge, which not only is worth a little bit of power, but more importantly, a safer tune up.
I'd much rather have the twin 600's on a 250 blower, than a single 1050.
MILD THUNDER is offline
Old 05-05-2015 | 08:27 PM
  #305
Yes. Blow thru, you can make 1200HP with a single 750 carb. Draw thru, that will never happen.
Old 05-05-2015 | 08:38 PM
  #306
KAAMA's Avatar
Yeah, I really thought it was kind of interesting...and I just thought 700hp @ only 5300rpm with those little Holley 600's was pretty impressive though....and 800 lbs of Torque. I wonder how many more RPM those 600's could have run on that particular engine before they would start giving up HP...???
KAAMA is offline
Old 05-05-2015 | 08:55 PM
  #307
SB
Blow thru changes the rules. per say. You are changing the atmosphere before your restriction vs after it.
Air flow's because of pressure drop. Depending onwhere these psi differences are, depends onwhat something will flow.
SB is offline
Old 05-05-2015 | 09:00 PM
  #308
Yes sir.
SB, what are your thoughts, on pressure drop, having an influence on temperature? And, a carb's venturi size affecting that phenomenon. Like, the old carb icing days...
Old 05-05-2015 | 09:21 PM
  #309
SB
Anytime you pick up air speed you'll remove more heat from surfaces....think winter ! Or brutal hot summer....we all feel this.
However,put a liquid in that ....think spraying carb cleaner with your fingers in the atomization,,,,and temps drop fast ! Lower than actual air temp...by a lot. here's your icing....and there is how AC works.
Thus why you need an intercooler on a dry intake system before you do with a wet system.
On a brutal hot day withno breeze stand there unil you can't stand it and then get in front of a fan. Great ! And then stand in frt of one with a water mist going thru it. Awesome ! Thenturnup the fan speed. Chilly ! Remember, you whereoverheating, now you have goosebumps and slightly uncomfortable due to the coolness. Air speed (same air temp) and liquid. Bingo.
SB is offline
Old 05-05-2015 | 09:27 PM
  #310
Rookie's Avatar
I've opened my hatch after a hard 10 mile run on a 90*F day and my carbs were covered in frost.
Rookie is offline
