Carb opinions 540's 700 hp... >
Old 06-13-2015 | 09:27 AM
  #401
Originally Posted by SB
I'm at work because an OE Ford power steering line I was putting in yesterday didn't have the threaded end pressed in all the way. Whore of a line to replace. Left at 9:30 last night and in early today.
People have no freakin idea how bad the screw ups are - more so from aftermarket, but still some from OE.
Doing re-repairs on your own time suks enough, try when it's shop time and that means other vehicles get put on hold and your employees are gonna make extra OT.
And then explain to your family why you don't come home until they are in bed and you lost $$$ at the same time.
Rant over - kind of - but everyone would be in for a rude awakening if they replaced parts everyday !
Edit in: don't forget my story the other day of a new GM longblock where one cylinder head did not have holes for the spark plugs. Solid cast iron there. F Me !
sb,i am willing to bet that facked up ps hose came from china or mexaco.it seems that more and more parts are no longer made by craftsmen in america but non skilled children from a foreign land.the person who gets stung from junk parts is the poor mechanic who is making the repairs.
mike tkach is offline
Old 06-13-2015 | 09:44 AM
  #402
Originally Posted by vintage chromoly
The reason someone would send a brand new carb to be gone over by a QUALIFIED carb shop is simple.
You do that to quantify that you have received what you were suppose to.
Same reason it's a good idea to have a qualified individual take apart and quantify brand new, out of the box, cylinder heads.
It does not surprise me in the least that these assembly line produced QFT carbs need looked at.
when the custom carb shop guy tells you that your quickfuel 850 has a 830 body all i can say is,RUN FORREST RUN.
Old 06-13-2015 | 10:07 AM
  #403
vintage chromoly's Avatar
Originally Posted by mike tkach
and if a person sends his carb to one of the custom carb shops and feels that when he gets it back it will be ready to bolt it on and run it with no adjustments he is wrong.IT WILL STILL NEED SOME ADJUSTING.
38 pages ago in post #25, VC said:
"I'm not expecting to put the carb on and not have to fine tune it on the water, but I wouldn't expect to be able to just bolt on any carb and be done".
vintage chromoly is offline
Old 06-13-2015 | 10:26 AM
  #404
SB
In my case, I'm the owner and my people are hourly. I had two who wanted to be flat rate - I was all over that ! - and then they asked to become hourly for the reasons of suck parts and Parts places (including many dealerships) in my area have button pushers.........Amt of wrong parts I get is staggering.
Warranty is almost non existent and they point the fingers at you because they have no understanding of repairs and that 'how can someone make so many faulty parts ?"
Tough I tell you.
Well, I'm done. Over 7hr into a 1.3hr paying job.
This reminds me, looks like my shop rate is going up ! I can only take it in the azz so much.
SB is offline
Old 06-13-2015 | 10:30 AM
  #405
yes you did.what is your point?my post was for all,not just you!
Old 06-13-2015 | 11:31 AM
  #406
Just that the rather obvious point that carburetors need fine tuned once in actual use was made on page three.
Carry on.
Old 06-13-2015 | 12:45 PM
  #407
Carry on.
thanks for bring it up,im glad you felt it useful.
Old 06-14-2015 | 06:17 AM
  #408
And for the record....once the "issues" were corrected on the "bad" QFT....these are a VERY TUNABLE carb! We are pulling at 2000...adjust for proper AFR, 2500, 3000 etc as we had a "flat spot" and got that curve straightened out.....Idle is clean, snaps right off idle...im Happy
TAStevens is offline
Old 06-19-2015 | 08:24 AM
  #409
Tim (Stevens) - since you didn't do a build thread, how did the engines turn out? Are you boating yet???
frickstyle is offline
Old 05-12-2016 | 09:27 PM
  #410
Originally Posted by Full Force
I am doing 540's afr 325 cc heads bob m cams nearly every person said to see 700 hp I need Dominators and that is my plan but what might be easier option if height is issue? I cannot go higher then my 4150's are now...
Just wanted to see combos and if using Dominators what kinda jetting to start with ...
Got caught up in this few different times briefly however what did you ever end up with and if dyno'd what hp and what carb?
getrdunn is offline
