Fuel Pump Question 548 ci with 256 blower
I'm working on a 540 (548) all refreshed, with a wieand 256 supercharger (dual carb set on on top, Holley blower carbs)
There is a mechanical fuel pump on top of the raw water pump, I believe it is a stocker (and it was on it prior to the rebuilds so it ran that way for some period of time) root cause of failure was a valve dropped into the cyl
the blower pressure is 4lbs ish (not huge boost)
Heads Are grumpy jenkins
Cam jb300 erson
And the engine is stroked...4.25 crank
The combo seemed to work well
Which fuel pump should I be using, I was told that I would need to go electric, I would believe I could get a mechanical that would support it and not have to redo the plumbing
I was told that these engines had alot of hours on them (I also know that they came from a sonic some years ago maybe built in 96 in the past perhaps somewhere on the east coat prior to transplant into the boat that I'm working on now)
Cam jb300 erson
