496ci 585hp tuneup >
496ci 585hp tuneup
496ci 585hp tuneup
Old 04-17-2015 | 04:44 PM
Originally Posted by SB
If Tbolt IV Set total timing to 32-34. You choose - it's your motor. Initial will be what it is after setting total.
Idle 800rpm if possible.
I would stay on the conservative side unless you know for sure what the compression ratio is. Cast iron heads or aluminum? If aluminum, it can handle a little more compression. You can get a ball park estimate of the dynamic compression ratio of an engine with a compression check, but it is just a ball park. If it is pumping out 185+ PSI, you can assume a healthy compression ratio and/or a cam with little overlap.
Budman II is offline
Old 04-17-2015 | 04:47 PM
Originally Posted by wannabe
That must be a one hell of a cam in that thing. 585 HP out of 496 cu in. Is this a Carb or Fuel inj motor.
Wannabe
Depends on the heads he is running. I built a 489 that dynoed at 585 HP with AFR 265 ovals, Dart oval single plane, 800 Holley and a relatively mild hyd roller cam. Heads can make a huge difference.
Old 04-17-2015 | 04:50 PM
As others said, unless it has a very radical cam, there should be no reason you can't get it to idle at 800 - 900 RPM, or even less. High idle speed can be hard on a Bravo's clutches. Would be a good idea to find out more about the cam specs and the exhaust to find out how low you can go without worrying about reversion.
If nothing was done to the engine since it was last run in the boat, and it was running fine then, why would you have to change the timing? Was this thing dynoed?
Old 04-17-2015 | 04:54 PM
SB
Exactly , and why I said - "it's your motor."
The OP gave us absolutely no usable info for us . Garbage in - garbage out.
So....what ever we give for info is woprth as much as what was given for us....Not much.
SB is offline
Old 04-17-2015 | 06:27 PM
Hey... it all about her...lol
TC9ball is offline
Old 04-17-2015 | 06:30 PM
SB
Holly ?
SB is offline
Old 04-17-2015 | 06:31 PM
Yeap!
TC9ball is offline
Old 04-17-2015 | 08:30 PM
Holly ?
Berry or Hunter,,maybe together.
sutphen 30 is offline
Old 04-17-2015 | 08:54 PM
SB
How about Holly Peers
SB is offline
Old 04-18-2015 | 07:34 AM
That works.
TC9ball is offline
