496ci 585hp tuneup >
496ci 585hp tuneup
496ci 585hp tuneup
Old 04-17-2015 | 12:49 PM
Default 496ci 585hp tuneup
My friend jyst got this really nice engine in 26ft celebrity Andretti... and it needs a tuneup. I'm thinking idle should be around 1000 ish and timing about 10btdc. ????
Thanks for your input.
Todd
TC9ball is offline
Old 04-17-2015 | 12:57 PM
Depending on the drive you will never get it out of gear if it idles at 1k
indysupra is offline
Old 04-17-2015 | 01:04 PM
can you give more info on the engine,like what ignition system,type of outdrive etc?
mike tkach is offline
Old 04-17-2015 | 01:06 PM
Bravo 1. Standard coil
TC9ball is offline
Old 04-17-2015 | 01:30 PM
That must be a one hell of a cam in that thing. 585 HP out of 496 cu in. Is this a Carb or Fuel inj motor.
Wannabe
wannabe is offline
Old 04-17-2015 | 01:36 PM
SB
If Tbolt IV Set total timing to 32-34. You choose - it's your motor. Initial will be what it is after setting total.
Idle 800rpm if possible.
SB is offline
Old 04-17-2015 | 02:40 PM
Total timing is 3000rpm..?
TC9ball is offline
Old 04-17-2015 | 02:41 PM
It has a holly.. wish I could post a picture...ugggg
TC9ball is offline
Old 04-17-2015 | 02:44 PM
SB
Many different modules out there...so.....
Total timing is where it stops advancing......
Example: was tuning a set of 525sc's. Was told those modules stopped at 3200rpm. Well, they didn't. They stopped at 4200 rpm. Imagine if I set total different than I do rpm wise ? Again, I go to where it stops advancing and then I bring it to a good 300-400rpm more to make sure it isn't advancing. This is no place to assume nor get fooled.
SB is offline
Old 04-17-2015 | 02:56 PM
SB
What does she have to do with it ?
SB is offline
