Morel 4603 lifter noise >
Old 03-17-2016 | 06:23 PM
  #91
To touch on sb's comment of running the oil the bearing clearances dictate, the stock sealed 500's I've had apart were right @ .002 rods and .0020-.0022 mains. Pretty tight imop to run 20w50
Unlimited jd is offline
Old 03-17-2016 | 06:55 PM
  #92
SB
Valid point. But (there is always a but right..lol) Merc suggests their 25W-40 right ? If cannot be found, 2nd choice straight 40w if over 50*F as next choice?
SB is offline
Old 03-17-2016 | 07:46 PM
  #93
I agree with the above, but heck, one of the most popular oils to run for years with merc 500's, and similar, was Mobil 1 15w50. I don't think anyone had any oiling issues with it.
Fwiw, out of my Merc HP service manual
800sc Mains 1-4=.0025-.003 , #5 .0035-.004 ,Rods .0025-.003
600sc Mains 1-4=.0013-.0025, #5 .0024-.004, Rods .0025-.0035
HP500 Mains 1-4=.0013-.0025 #5 .0024-.004 Rods .0009-.0025
Thats production specs. Service specs, are a bit looser than that.
In this merc manual, it states that a 20w50 is recommended, or , a straight 40 weight if operating over 50 deg F. If operating between 32* and 50*, a straight 30 was recommened. . It covers the 525sc, HP500, 600sc, 800sc.
MILD THUNDER is offline
Old 03-17-2016 | 09:18 PM
  #94
blue thunder's Avatar
My own experience with morel link bar lifters is they are finicky to set. I can build 2 engines side by side, set both at 7/8 turn down (mid plunger travel), one quiet on start up the other slight cold chatter with 15-50 mobil 1. In every case I've been able to add 1/8 turn to the engine that has slight pre oil temp chatter and make it quiet.
blue thunder is offline
Old 03-18-2016 | 08:13 AM
  #95
Funny how everyone treats merc blue motors like the jewel of the Nile, I know my clearance tolerance is a lot closer than that. That manual reads like that of a gmc truck dealer.
Might as well say "as long as it spins, but doesn't wobble you're good"
Old 03-18-2016 | 08:40 AM
  #96
Mercury racing might not be the jewel, but how often do their engines melt down with spun bearings, or oiling issues with 20 hours on them.
Old 03-18-2016 | 08:50 AM
  #97
^^^ Mine & Joes are right there or a bit looser.
Rather have em looser than tighter.
Merc motors last, I would say they`ve probably done some research on that.
ICDEDPPL is offline
Old 03-18-2016 | 09:00 AM
  #98
hp500 mains .0013 .0025.to me .0013 seems way to tight..0025 to .0035 is how i roll.i doubt ANY hp500 was ever built that tight.also .0009 rod clearance just plain scares me.
mike tkach is offline
Old 03-18-2016 | 09:01 AM
  #99
Runem loose! When I first starting with engine builds I was anal about going by the book on everything and then I woke up one day. All that is for ref and general information. Colder the oil temps the more the clearance.. This is a case where it's ok to NOT hit the side walls as long as your crank bottoms out. Little Friday humor. Ha
getrdunn is offline
Old 03-18-2016 | 09:03 AM
  #100
Originally Posted by mike tkach
hp500 mains .0013 .0025.to me .0013 seems way to tight..0025 to .0035 is how i roll.i doubt ANY hp500 was ever built that tite.
My last builds were .0035 and they ran forever.
getrdunn is offline
