Engine developed "chirping" sound from stbd side exhaust
#41
I also have a chirping sound in my new build. Mine sounds like it is located near the distributor. It goes away over 1200rpm, returns at idle. Morel high rpm lifters 5w30 dino oil.
I will be tearing the engine down to rectify a blown head gasket on my AFR 305 heads I bought here on OSO, so I will look at the cam and lifters.
#42
#43
Plugs looked OK when I pulled them last year. I'm sure they are pretty fouled now. I had a brain fart and started the motor on the hose last fall with the electric choke disconnected, so it idled real fat. It smelled rich at idle this last time I had it out, and I suspect that I may need to check my float levels. Probably need to drop it in the water to get that right, because the attitude will probably be wrong sitting on the trailer.
#44
#45
Nope!
Engine has about 20 hours on it now. Wouldn't I expect that to rear its ugly head within the first few hours? It hasn't been run in any extremely cold water. Lake water temp was about 89* when I ran it last weekend.
#48
I've got the same noise I believe. Much more noticeable from the engine than the exhaust.July 28, 2015: https://youtu.be/QX6qU_QzkLE
Straight bottoms and flat decks
#49
#50
Yeah. I always thought it sounded like crickets. The sound and video deteriorated quite a bit during the upload. Much more noticeable on the original.
