Engine developed "chirping" sound from stbd side exhaust
#31
#32
I appreciate all the replies! I am going to have to investigate this a little more thoroughly. RT930turbo has me a bit spooked - I would hate to wipe out an expensive cam and lifters on something like this. I'm going to run it on the hose and get a good close look at it, maybe even take a little video, listen around with a stethoscope, etc. Probably run a quick compression check at the minimum. If still not satisfied I'll pull the intake and have a look.
Full Force, come to think of it I was having some impeller issues, so probably not as much water was exiting the exhaust. I had smoked an impeller last year on the hose (did not overheat), and put in an aftermarket one that is not building goo water pressure. I was running between 5 - 7 PSI even at 3000 RPM over the weekend. Oil temp stayed at around 190* and water temp was around 150*, so no harm done, but it should be a lot higher than that. At idle it was barely reading on the gauge, although I could still see water coming out the exhaust.
#35
my boat has the same noise.afr 265 heads.stock 454 mag short block.bob mandera cam.scorpion rockers.had morel roller lifters now has johnson roller lifters.stainless marine exhaust.didnt do it until i upgraded the engine.went so far as to pull the head back off mine found nothing.has been doing it for going on 3 seasons.if you guys figure it out let me know.haha
#36
RT, mine doesn't really sound like a squeak so much. More like a ping or a chirp. Sounds a lot like Force's video. I just don't remember it being that prevalent last year, if I heard it at all. Part of my worries are the fact that I had fuel delivery issues at the end of last season and did not get my anticipated top speed on the one full throttle run I made all season. I'm afraid I leaned it out and possibly damaged something, hence my paranoia about any new sounds.
You guys are correct - impossible to diagnose via keyboards, as much fun as it is to conjecture. I definitely appreciate all the suggestions on things to check. Hopefully I can get it on the hose this afternoon.
It sure makes it even more fun to have the wife asking me "what's wrong with the boat this time?" every time I have the hatch up on it. I guess the next time she buys another pair of black shoes I'll have to ask her "what's wrong with the other 57 pairs of black shoes you have?" I'll probably have to go out and swipe an engine out of someone's Suburban if this thing goes south again.
Last edited by Budman II; 07-28-2015 at 06:30 PM. Reason: clean up after ten thumbs typing
#37
#38
Mine at idle no issues... Is this what you hear?
http://www.youtube.com/attribution_link?a=yFLhHHqKOXs&u=/watch%3Fv%3DHrOnCf1AMt4%26feature%3Dem-share_video_user
#39
had a cam/lifter failure that was my mistake.went back to bob mandera for the exact same parts becuase my previous set up had exceeded my expectations.bob recommended the johnsons so i went with them.they both seem to be fine.havent made a full throttle pass on the motor yet.it does have some issues i didnt have before but i cant tell you if its related or not.
#40
RT, mine doesn't really sound like a squeak so much. More like a ping or a chirp. Sounds a lot like the Force's video. I just don't remember it being that prevalent last year, if I hear it at all. Part of my worries are the fact that I had fuel delivery issues at the end of last season and did not get my anticipated top speed on the one full throttle run I made all season. I'm afraid I leaned it our and possibly damaged something, hence my paranoia about any new sounds.
