Need a compact alternator - 496 manifolds on 454 Mag >
Old 08-06-2015 | 01:36 PM
TomZ's Avatar
Originally Posted by apollard
I'm surprised, as I have 496 manifolds on a Mark IV block and had no issues putting a full size 10SI alt on using stock brackets. Had to do a little grinding for PS pump, but got it to work also.
What gen block is yours?
It's a MK IV. My 496 manifolds are the older style with the separate water rail. The clearance issues are at the water rail casting.
I'll measure the 10SI that I have in the garage. If it's even a half inch shallower front to back, I'll just order a replacement. I have the factory Prestolite on it now.
TomZ is offline
Old 08-06-2015 | 01:37 PM
TomZ's Avatar
Originally Posted by BUP
I was going by the ad as it says marine as well - that is for the buyer to completely to do the homework to find out if they are coast guard approved and spark resistance. I throw it up as I seen them before listing as marine.
Was just pointing it out in case someone else wanted to use the info. Thanks again for the direction!
TomZ is offline
Old 08-06-2015 | 06:23 PM
Ah, that must be it. Mine don't have the rail.
apollard is offline
Old 08-06-2015 | 06:36 PM
BUP
he should have the Aluminum manifolds version then with the rail - correct ?
BUP is offline
Old 08-06-2015 | 09:33 PM
Yes, at least As I understand the 496 manifolds
apollard is offline
Old 08-07-2015 | 07:42 AM
TomZ's Avatar
Yes, they are the aluminum version.
TomZ is offline
Old 08-07-2015 | 10:21 AM
TomZ's Avatar
I went ahead and bought the IMCO relocation bracket that was on eBay. My alternator was working fine, and I figure it's better to just go with the easy fix. Lots of these things have popped up, and I'm happy to have found a simple solution.
Thanks for the direction everyone! That's what I love about this forum... lots of good support!
TomZ is offline
Old 08-31-2015 | 11:04 AM
TomZ's Avatar
Anyone got any more advice? I bought the IMCO relocation bracket that was referenced... no joy. Fitment is even worse now.
Has anyone had any luck with running 1-wire alternators vs the 3-wire? I might be able to make a Delco 10si alternator work.
TomZ is offline
Old 08-31-2015 | 11:20 AM
You can buy the 10si based marine alts in a 3 wire version. I run one. I would stick with the 3 wire instead of the 1 wire. Best explanation I've seen for this here http://www.madelectrical.com/electri...hreewire.shtml
apollard is offline
Old 08-31-2015 | 11:24 AM
I have been running 1 wire marine alternators for about 4 or 5 seasons now . No issues with them.
MILD THUNDER is offline
