Need a compact alternator - 496 manifolds on 454 Mag >
Old 08-05-2015 | 04:15 PM
TomZ's Avatar
Default Need a compact alternator - 496 manifolds on 454 Mag
454 Magnum set up with Merc 496 exhaust manifolds. The manifold hits the alternator.
What's a good, compact replacement?
Any ideas?
Thanks!
TZ
TomZ is offline
Old 08-05-2015 | 04:32 PM
Tom, can you go to a low mount alternator bracket?
http://www.cpperformance.com/p-13713...acket-kit.aspx
MILD THUNDER is offline
Old 08-05-2015 | 04:59 PM
TomZ's Avatar
Joe,
I don't think that would change it much. That bracket looks like it's in the same basic position.
TomZ is offline
Old 08-05-2015 | 10:17 PM
This is what my guy used to solve the same problem when I put 496 exhaust on a 454.
http://www.ebay.com/itm/BBC-Imco-Pow...item25a41e41be
BGIII is offline
Old 08-05-2015 | 10:41 PM
BUP
70 amp mini - yours was most likely a 65 amp if I recall correctly.
http://www.ebay.com/itm/like/1515714...lpid=82&chn=ps
BUP is offline
Old 08-06-2015 | 09:39 AM
TomZ's Avatar
That's not a marine alternator... but it looks like a Denso will fit.
TomZ is offline
Old 08-06-2015 | 09:41 AM
TomZ's Avatar
Using that bracket, did it keep the belt alignment the same across everything? Power steering and alternator? I'm using a B&M blower and cannot make changes to the accessory pulley configuration.
TomZ is offline
Old 08-06-2015 | 09:59 AM
That I am not sure of. Martin's Custom Marine did the work for me, you might want to PM him.
http://www.offshoreonly.com/forums/m...tom-marin.html
BGIII is offline
Old 08-06-2015 | 11:22 AM
BUP
I was going by the ad as it says marine as well - that is for the buyer to completely to do the homework to find out if they are coast guard approved and spark resistance. I throw it up as I seen them before listing as marine.
BUP is offline
Old 08-06-2015 | 01:12 PM
I'm surprised, as I have 496 manifolds on a Mark IV block and had no issues putting a full size 10SI alt on using stock brackets. Had to do a little grinding for PS pump, but got it to work also.
What gen block is yours?
apollard is offline
