Talon wouldn't fire yesterday at the ramp >
Old 08-19-2015 | 09:40 AM
Dean what kind of exhaust headers are you using? very nice looking engine!
two7pro is offline
Old 08-19-2015 | 01:58 PM
Dean Ferry's Avatar
CMI's polished E-tops:
http://teaguecustommarine.com/em0011...ished-kit.html
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 02-05-2016 | 06:30 AM
Dean Ferry's Avatar
Update, Finally took so time off from work, replaced coil, and still no fire. Got dark, didn't get to check for +12VDC at the coil + term. Anyone know a good Merc. tech. in central Fl? I don't have time to work on it, and I need to get her sold before March....
Thanks,
Dean
Old 02-05-2016 | 07:40 AM
since it is MSD ignition, i don't think you need a merc tech,, You just need someone that understands ignitions. Since I think you said it is a stand alone and you have replaced coil,??.Not many parts left .. If your battery is weak an MSD system won't work below something like 8-9 volts. Check battery voltage while spinning engine over with starter and see what it is...JMO and good luck. edit .Almost forgot ..Unhook tach and any wires connected to coil that aren't ignition related...Like an interrupt switch on -...electric choke possibly hooked to +...etc..
motor is offline
Old 02-05-2016 | 08:49 AM
Revelocity's Avatar
Originally Posted by Dean Ferry
Thanks that's 1 of the 1st things I verified at the ramp,+12.3 VDC on the + terminal of the coil. Also, verified the lanyard is the not the problem.
I had a lanyard situation on my MSD box and blaster coil last spring. The faulty lanyard switch wasn't activating the MSD box's internal power relay. Jumped the lanyard and it started! I'm installing a 2 wire Weatherpack connector for power and ground to allow easy swap out of the MSD box on the water as it seems to be "not if but when" there'll be a problem. Good luck.
Revelocity is offline
Old 02-05-2016 | 09:01 AM
fandango's Avatar
From: Solomons Island, MD, Vero Beach and Punta Gorda, FL
He does not have a box, just ready to run distributor and coil. I have same on my back up motors. Simple system. Need to check for 12Vt at coil.....but I think you already know this.
Ed
fandango is offline
Old 02-05-2016 | 09:44 AM
Wally's Avatar
Were doomed!
If you have 12+ on the coil + terminal then it sounds like you have either a ground problem....or theres a connection issue between the coil and the distributor....could be the quick connect from the distributor.....
-Wally
Wally is offline
Old 02-05-2016 | 09:46 AM
change dist. they have a internal module, and if like most all other MSD(may soon die) bet that where the issue is, I run the H/P HEI dist, simple never had a failure
ezstriper is offline
Old 02-05-2016 | 09:54 AM
Originally Posted by blue thunder
Check for voltage with the key on at the + side of the coil. Also in case you missed it, check your lanyard. It actually opens the wire going to the + side of the coil when activated to kill spark.
^^^^ By-pass your dash saftey Teather / Laynard. (backside should be removable male/ female as on most style switches.) then verify voltage.
I know its been mentioned. Years ago my Sea Ray would die after 15 minutes of running.. then 10 then 5 then gladly it died completed . I may have never found it intermittently but I lucked out.
cmattj is offline
Old 02-05-2016 | 10:27 AM
As a side bar-- I read a lot about these kill switch malfunctions -- is it possible the reason why so many have had issues is that we don't use them -- In other words should we routinely toggle the switch up and down (or in and out) to get rid of any corrosion/nasty's--- just a thought.
3pointstar
3pointstar is offline
