Fogging for winter >
Fogging for winter
Fogging for winter
Old 09-16-2002 | 06:09 AM
Rick252
Default Fogging for winter
Whats the best way to fog a MPI engine?
No, I'm not taking it to San Francisco
Old 09-16-2002 | 10:13 AM
Panther's Avatar
Frank's Marine Service
Default I've done it two ways
I have winterized the MPI's two ways. First was to run the motor off a separate tank with a mix of gasoline, sabilizer, and fog oil mixed. It takes a while to run it thru the system though.
Another way is to add fogging oil to the fuel pump housing. There is an access hole on the top of it.
Don't spray fogging oil thru the butterflies, because it puddles in the intake. When you shut the motor down it can drain into the cylinders and hydralock it when it comes time to start it up in the spring.
Panther is offline
Old 09-17-2002 | 07:39 AM
DaveHam's Avatar
Check with your Mercruiser dealer as there is a new procedure on winterizing MPI motors.
DaveHam
DaveHam is offline
Old 09-17-2002 | 08:05 AM
DonMan
Hey Rick, just move down here to Texas. The winter down-time is so short, there`s really no need to fog it. But you know, I have been wondering how you would do it on a MPI.
Old 09-17-2002 | 12:15 PM
djm's Avatar
djm
the boatered.com site suggests mixing 2-stroke oil into the fuel water seperator and running it till the exhaust gets smoky. Seems simple enough
djm is offline
Old 09-17-2002 | 12:24 PM
Shorty's Avatar
I used the 2-stroke oil like that last year, piece of cake.
Ran boat up to temp, killed it. Drained the block, hooked the muffs to the antifreeze bucket, filled the fuel water separator half full of 2-stroke oil/half fuel/shot of Heat, ran till emptied anitfreeze bucket.
It didn't take long, but it's a hectic few minutes. Want to do it all before engine cools and closes the thermostat.
Shorty is offline
Old 09-17-2002 | 02:48 PM
ursus
Merc Recomends filling the fuel filter with fuel stabalizer and running the engine for at least 1 min not more than 2 min on EFI engines. This is so the injectors don't stick over the winter when the gas evaporates the detergent in the gas is apearantly like Glue. I don't know if it happens over 1 winter but happened to me on one that sat 1 1/2 years 8 injectors all stuck.
davis777
19
10-05-2011 10:15 PM
Magicfloat
06-07-2007 07:48 AM
wrinkleface
10
10-01-2006 07:56 AM
BajaRunner
11-01-2005 12:38 PM
Mr.Gov'nt
11-20-2002 09:06 AM
