What do these bearings tell you? >
Old 10-12-2015 | 07:26 PM
  #91
donzi matt's Avatar
Originally Posted by bck
Water temp never moved. Oil temp on only one engine went up to about 240. Maybe a minute or so at that temp
Where is your oil temp measured, pre cooler or post cooler? I don't see 240 degree oil temp pre cooler causing this. I see it possibly being a symptom of the meltdown happening. What RPM were you at when this burned down, cruise or WOT? From the pictures the skirt clearance looks like it could have been tight, but if it was running lean and detonating you could have the same problem.
donzi matt is offline
Old 10-12-2015 | 07:29 PM
  #92
bck's Avatar
bck
Charter Member#568
MT can you post a pic of the plate with the holes drilled in it on your pickups? I'd like to see it as I think I'll do the same. Thanks
Straight bottoms and flat decks
bck is offline
Old 10-12-2015 | 07:34 PM
  #93
bck's Avatar
bck
Charter Member#568
It was about 5200. Afr at that rpm was probably 12's. I have to go by memory cause its tough to write legibly at those speeds. I honestly don't know if that's before or after the cooler. I'm using the threaded fittings on the remote oil filter/ thermostat housings. I'd have to trace the lines to determine before or after the coolers. Is there a standard it should have been set up for?
bck is offline
Old 10-12-2015 | 07:37 PM
  #94
bck's Avatar
bck
Charter Member#568
Originally Posted by SB
WOW ! You had some hardware !
These engines were spec'd for a 357 formula with kaama's and a wet exhaust. They are now in a different boat. * note going from tall deck to short requires new tailpipes. Who woulda thought 4/10ths would make such a difference?
bck is offline
Old 10-12-2015 | 07:44 PM
  #95
I'll try to get some close ups next weekend of them. This is all i have for now, which isnt very helpful
MILD THUNDER is offline
Old 10-12-2015 | 07:49 PM
  #96
I made it work in my Donzi with an oversize ring and you could never tell. But then again I'm not a professional rigger I'm just a grease monkey and knuckle buster.
Black Baja is offline
Old 10-12-2015 | 07:52 PM
  #97
bck's Avatar
bck
Charter Member#568
They were off pretty far. I've got pics somewhere. No way it was going together without cutting/ welding.
bck is offline
Old 10-12-2015 | 07:54 PM
  #98
bck's Avatar
bck
Charter Member#568
Thanks. Even after cleaning the strainers the intake had a baseball sized wad of seaweed up inside it. I have the exact same pic you do. If you blow it up you can see the intake. No screen at all and it was plugged.
bck is offline
Old 10-12-2015 | 08:02 PM
  #99
On the remote filter is most likely before the cooler. (The way most stuff is rigged) You can get a bunch of discussions about where and why you should check oil temp before/after cooler. Mine was always before, and ran 230 all day long for 5 years, with no issues.
Zone 5 is offline
Old 10-12-2015 | 08:09 PM
  #100
donzi matt's Avatar
Crap, I missed your reply. Yes the filter housing is pre cooler, so 240 wouldn't have me worked up as to the cause of the failure. I am really curious what your skirt clearance is.
