What do these bearings tell you?
#71
Carbs were not Quick Fuels. I'm not happy with the carbs but I don't believe they are involved here. Except as it might relate to the engine problems, I'm going to leave the carbs out or now.
Straight bottoms and flat decks
#72
What's the chances you gas washed the cylinders during tuning? I have seen it before on a carbureted engine killed the cylinders from the choke staying on.
Where any of the second rings stuck?
Or it was lack of clearance piston to wall its in bad shape.
Now I see its carbureted from pictures.
#76
How long did this run hot for? It looks like a heat seizure to me and that could also explain the detonation you see on a couple of plugs, especially if this thing ran hot for a bit before you noticed it. Do you have any pistons that are not damaged that you could measure to see what skirt clearance was?
#77
Pistons look like a clearance issue to me. It's pretty well understood in the marine industry that you add a little more piston/bore clearance for the hot piston/cold water condition a lot of boats see (without enclosed cooling systems). From other things I see, this engine builder may not have done that, may not have know that. If the cyls were out of round and tapered, then there may have been ring sealing issues allowing oil contamination in the chambers which will almost assuredly lead to detonation. The valve train is a no brainer, but I will say that's why I'm not a fan of the Jesel Sportsman shaft rockers because of this potential. They really offer nothing over a good stud mount system with a girdle. If you want shaft rockers, get something with a one piece intake stand.
And I will NEVER touch the face of a bearing with anything other than a quick wipe with white ScotchBrite but that's just me.
#78
#79
All irrelevent at this point. Time to rebuild from scratch. What a mess. That really sucks.
I see your in western NY. Why not just drop them off at marine kinetics shop, for full machine work, balancing, assembling, and dyno testing. They do carb mods as well if the prosystems need modding
http://www.marinekineticsonline.com/services.html
