What do these bearings tell you? >
Old 10-08-2015 | 10:25 AM
Originally Posted by bck
While we're at it.
I'm sure this had something to do with the looks of the bearings.
Black Baja is offline
Old 10-08-2015 | 10:28 AM
bck's Avatar
bck
Charter Member#568
Originally Posted by 30ftpanther
If the mains in block were 0.005" to big scotch brite would make it worse.
Right. Don't know for sure why stuff was done
Straight bottoms and flat decks
bck is offline
Old 10-08-2015 | 10:30 AM
bck's Avatar
bck
Charter Member#568
Bores were out of round and tapered. Although I did get them hot
bck is offline
Old 10-08-2015 | 10:33 AM
Do you know what the bearing clearances were? .0035? Bigger?
Mr Maine is offline
Old 10-08-2015 | 10:34 AM
bck's Avatar
bck
Charter Member#568
And there were .180 of small block shims under the springs.
bck is offline
Old 10-08-2015 | 10:36 AM
I was referring to the detonation on the Pistons. It will hammer the hell out of the bearings.
Old 10-08-2015 | 10:40 AM
bck's Avatar
bck
Charter Member#568
What do you see in the way they look? Are you referring to the dirt that sutphen mentioned? Trying to at least learn a little from the experience * edit just saw your reply. No one else mentioned detonation. What are you referring to.
bck is offline
Old 10-08-2015 | 10:44 AM
bck's Avatar
bck
Charter Member#568
Comp was 9.0 , 36 ° timing, 93 octane
bck is offline
Old 10-08-2015 | 10:47 AM
SB
Post #7. 1st photo.
SB is offline
Old 10-08-2015 | 10:50 AM
The top of the piston in the one pic looks like it was sand blasted. That from detonation. The pic to the right of that one looks like it has a small chip missing around the outside (exhaust side) that's detonation. If you have the Pistons out and flip them upside down I bet they have burnt/ baked oil on the backside this is due to detonation. You probably also have black stripes on the sides of the Pistons this is from detonation. That's why it is often referred to as Black Death. Do not re-use those Pistons. At a minimum you need to carefully measure the ring gaps in them. What happens when they detonate is it shakes the hell out of the rings and the ring land gets oblonged in the back of the groove. Also when they start shaking you loose seal and end up with the black stripes on the sides of the Pistons. Detonation will eat the bearings right out of a motor. Make sure you have the main line checked carefully as well as the deck of the block (front to back side to side). It can and will move things all over the place.
