What do these bearings tell you? >
Old 10-08-2015 | 10:51 AM
bck's Avatar
bck
Charter Member#568
I was looking at the scoring in the bores. I thought bearings looked good except for the uneven wear and scotch brite marks. Might have been the flash making pistons look like that. Afr got into the 13s when cruising. Was in the 11 and 12s at all other times including wide open iirc
Attached Thumbnails What do these bearings tell you?-imag1188.jpg   What do these bearings tell you?-imag1175.jpg   What do these bearings tell you?-imag1174.jpg
Straight bottoms and flat decks
bck is offline
Old 10-08-2015 | 10:56 AM
Oh yeah you detonated the piss out of that thing. Throw the valves away also.
Black Baja is offline
Old 10-08-2015 | 10:58 AM
14 apache's Avatar
One more thing you will see is the second ring will be pinched from the hammering on the top ring.
14 apache is offline
Old 10-08-2015 | 11:05 AM
14 apache's Avatar
I think that might be getting a little lean at cruse in a boat.
Plus you said it got a little hot that will also cause it to detonate.
bck's Avatar
bck
Charter Member#568
The tops of the pistons look uniformly black and sooty to me?
bck is offline
Old 10-08-2015 | 11:13 AM
bck's Avatar
bck
Charter Member#568
I think some of what you're seeing might be from the camera. Look how different the valves look in the pics above and the different color on the pistons from last page to this page
bck is offline
Do the spark plugs have any black spots on them? Is your timing locked at 36?
Old 10-08-2015 | 11:22 AM
bck's Avatar
bck
Charter Member#568
Crane marine ignition boxes with the built in curve.
Attached Thumbnails What do these bearings tell you?-imag0951.jpg   What do these bearings tell you?-imag0948.jpg
bck is offline
Old 10-08-2015 | 11:30 AM
bck's Avatar
bck
Charter Member#568
The 2 bottom pics at the top of the page most accurately show the color.
bck is offline
Old 10-08-2015 | 11:32 AM
I tried to supersize the plug pic but it get blurry. Look for black spots on the porcelain...
