Cam selection
#31
Lunati, howards, comp, and others all use austempered cores , hence their price of 275-300 a cam. I know lunati will grind any of those cams on a billet core for an upcharge. I would bet there are tens of thousands of austemempred cores out there doijg ok on the basic bbc ....heck, lots of guys i know are worried about getting an 8620 cam core, but stil running a cast cam gear timing set
#32
Memory refresh time.
Remember way back when all those Crane's where breaking ? The cam literally broke just before the dist gear.
I remember a heat treat difference between those breaking and not, but can't remember if there was a core difference.
#33
I remember reading about that , here. It wasnt the 8620 cores, but another core they were using. Not sure if it was a material issue, or design issue though
#35
Depending on what the core material is dictates the hardening process.
#36
i remember reading about the crane stuff breaking they cheapen up their heat treat process and materials I believe you can tell the difference by the color of the core between lobes they loss that traditional gold color on the cheap ones anyone know of a place to have my Gil tails lengthen on the inners near buffalo?
#37
#39
Here is a good post on materials and heat treat by Kip Fabre of Cam Motion:
http://ls1tech.com/forums/generation...l#post18547331
