Camshaft Selection/Engine Setup
#31
Same setup, it was just tired and had 2 damaged cylinders and 2 burnt valves. I can't tell what cam was in it before because there was minimal markings that were able to be read when I removed it. So all I am basically doing is building the same bottom end, changing the cam, clean up the heads, and adding some timing.
#32
I have RPS302 in my cart right now which was recommended by Comp Cams. Will this Rocker Arm kit work with the 088 Heads that I am using? I also assume that I will reuse the dog bones and spiders when I install the 900-16 lifter kit as well?
