Engine Quest Head work results >
Old 03-13-2016 | 10:46 AM
  #51
Im sure haxby is capable of forming his own opinion. He simply asked if foxwell had flowed a set of 325 afrs.
MILD THUNDER is offline
Old 03-13-2016 | 06:36 PM
  #52
Just thought I'd post this for all to see. I can't support the authenticity of however take a look.
Attached Thumbnails Engine Quest Head work results-image.jpg   Engine Quest Head work results-image.jpg   Engine Quest Head work results-image.jpg
getrdunn is offline
Old 04-05-2016 | 01:25 PM
  #53
Panther's Avatar
Frank's Marine Service
Just a quick FYI. If you're going to use the Merc oil pain and dipstick, the EQ heads do not have the 1/4 20 hole in the head to the upper right hand side of the exhaust port and you'll need to drill and tap the head.
It's an easy fix, just an FYI for those who are adding these heads.
[ATTACH=CONFIG]553587[/ATTACH]
Panther is offline
Old 04-05-2016 | 01:40 PM
  #54
^^^ I used a step bit, opened the hole up on the dipstick hanger and moved it to the front
endeavor1 is offline
Old 04-05-2016 | 01:46 PM
  #55
Panther's Avatar
Makes sense. These are MPI engines so there's a lot of bracketry up there.
Panther is offline
Old 04-05-2016 | 02:30 PM
  #56
Same issue with my Dart 308s. I just used the bolt that holds the fuel water separator to its bracket mount. One other annoying thing is all the accessories on the GM heads were 7/16 bolts, and the Darts are all 3/8. Just adds more time especially when doing two engines.
Mr Maine is offline
Old 04-05-2016 | 02:51 PM
  #57
SB
A good amt of other Aftermarket heads do this too.
SB is offline
Old 04-05-2016 | 07:52 PM
  #58
Overall, I'm pretty happy with the purchase. While they flow better than my old heads, I like that but more importantly though, I am much more happy about the work setting the heads up this time around.
Last shop, I paid good money, like 2500 to rebuild two sets of dart heads for me. They installed new valve seats, which was half azzed done, weren't even the right seats for those heads, they probably had them laying around the shop, and installed them. Install heights were all over the map, some at 2.020, some at 2.050 , some at 2.000, not a single shim anywhere to make up any differences. Using a .680 ID locator, with a .740 spring inner ID, which was causing the spring to wear on the valve seals, retainers and locators showed signs of severe spring rotation, cutting into the steel on them. and set the springs up over 1/4 inch from coil bind.
The new shop I used, set everything up beautifully. No more varying install heights, springs setup .090 from coil bind. Each spring was individually tested for consistant pressure, and coil bind , which actually resulted in finding 1 incorrect spring in the batch of 32 that got slipped in the new packaging.
We opted to run without the little spring on the exhaust valve seals, like merc did on their supercharged engines, getting a little more oil to the ex guides. Added stud girdles, and replaced the crane alum rockers with Comp's new Ultra Pro Mag XD steel rockers.
Attached Thumbnails Engine Quest Head work results-20160404_162535.jpg   Engine Quest Head work results-20160404_162620.jpg
Old 04-05-2016 | 11:03 PM
  #59
I think steel rockers are the way to go. Bad application for aluminums fatigue life.
hogie roll is offline
Old 04-05-2016 | 11:04 PM
  #60
If you get your valvetrain sorted and spin those babies up, you should make some big power.
