4150 to 4500 adapter >
Old 04-15-2016 | 05:37 PM
Rookie's Avatar
Default 4150 to 4500 adapter
I need an adapter to maybe make some pulls on the dyno (557) to compare a 4150 900+ custom carb vs a 4500 1050. Didn't have time or want to pay $$ for one so I just printed one off my 3D printer. Need to add some brass inserts for the bolts. I'm going to start printing some gaskets next. Technology is pretty cool.
[ATTACH=CONFIG]554194[/ATTACH]
[ATTACH=CONFIG]554195[/ATTACH]
Attached Thumbnails 4150 to 4500 adapter-20160415_181337.jpg   4150 to 4500 adapter-20160415_181347.jpg
Rookie is offline
Old 04-15-2016 | 05:49 PM
What you can do with a 3D printer is pretty cool.
endeavour32 is offline
Old 04-15-2016 | 07:46 PM
Tinkerer's Avatar
IF you are not going to run a 4 hole spacer under the adapter I would be a little worried about the center piece coming out. They usually have a little more meat supporting itl
Tinkerer is offline
Old 04-16-2016 | 06:49 AM
That looks cool! Did you use nylon? I ended up buying a taz 5, thing is awesome! I built a heat chamber for it to make printing ABS more reliable!
502ss is offline
Old 04-16-2016 | 08:02 AM
Rookie's Avatar
I printed it in PETG. I think I would have to much warp with nylon for the overall size. I've had some PETG, TPU, Ninja Flex and Semi-Flex sitting in gasoline for a few days to test the chemical resistance.
Yeah, I love my Taz 5. I still believe it's the best bang for your buck. What issues were you having with ABS?
Rookie is offline
Old 04-16-2016 | 08:08 AM
SB
Heh, since you'll have the two carbs, if you show us the dyno results here, could I trouble you to note the sizes of the venturis and throttle bore's of the two carbs along with noting what type boosters ? Just wanna' see how close the stated cfm's are to the actual carb sizes.
SB is offline
Old 04-16-2016 | 08:03 PM
The biggest issue with ABS is controlling the warp when printing large parts. Small parts are fine because of them being close to the heated build plate but as the part moves away from the build surface it cools too quickly. I keep the build chamber about 105 Fahrenheit with no cooling fan and I have awesome results!
Here is my build chamber. All made out of 80/20 extruded aluminum and lexan! All the hinges, locks and corner pieces are of course printed!!
502ss is offline
Old 05-14-2016 | 06:16 PM
Rookie's Avatar
SB, I wrote down the numbers down real quick. Sorry I didn't get these sooner.
Did not use the 1050, borrowed an 1150 Dominator that was tuned on a NA 598 850HP.
The 4150 flowed ~1000CFM I'll try to get the measurments if the carbs are still at the shop.
I just wrote down the 5000RPM and up #'s
Left 1000 CFM 4150 / Right 1150 Dominator
.....TQ ..... .....CTQ..........HP..........CHP..... RPM
655/668.....697/711.....624/636.....663/677.....5000
654/662.....696/704.....685/693.....729/738.....5500
634/650.....675/692.....724/743.....771/790.....6000
616/632.....655/672.....733/752.....779/800.....6250
598/612.....636/651.....740/757.....787/805.....6500
585/590.....622/628.....752/758.....800/807.....6750
Rookie is offline
Old 05-15-2016 | 09:12 AM
So what are you going to end up running?
getrdunn is offline
Old 05-15-2016 | 01:51 PM
bck's Avatar
bck
Charter Member#568
I know this is more about the 3d printer but as comparison we picked up 12-15 hp and improved the entire curve by swapping a 4150 for a 4500 on a 4150 flanged Vic Jr. 2 in. spacer on both.
Straight bottoms and flat decks
bck is offline
