Replacing Impeller - Just the impeller or entire assembly?
#31
Yes , one seal keeps the water on the water pump side and the other keeps the gear lube on the fuel pump side. They are installed opposite each other, pay attention to the way they face when you press the cam / impellor shaft out. Bam has a good exploded view on their website if you don't have the factory service manual. Bam also sells the manuals, best $ you will ever spend on your boat!
Ok, so the seal only separates water from fuel/oil and there's no fail safe to keep fuel out of the oil? Just have to keep changing it and pray for the bearing?
I just installed Hardin SS housings (OE looked to be original at 20 yrs./235 hrs) but I'll be replacing the impeller once/yr.
#35
