Carb size
Old 05-19-2016 | 08:20 PM
  #31
Originally Posted by mcollinstn
You want to carb it for max power? Any wide-open vacuum more than 1.3" is hurting your max output.
If I'm looking for all out max for a combination, I don't want to see more than 1.0" of vacuum.
But, if you carb it for less than 1" of vacuum, it will not behave as well when nursing the sticks in rough water since the signal thru the venturies is weaker at real low vacuum. You can make up for it with the accel pump cam, but then you end up squirting the heck out of fuel in there. If you commonly run wide open in rough water where you have to be constantly on the sticks, then stay above 1.5" of vacuum wide open.
Tapping for a vacuum gauge? if your intake doesn't have a tap, most carbs either have a port on the baseplate OR many are spotdrilled in the correct location for you to install one there.
Having a vacuum gauge hooked up also helps you get your idle mix and static timing figured out. Sometimes hotrod boat motors end up with way too little initial timing, and too much centrifugal advance with soft springs that end up with "hunting" off idle around the docks. It's not just a supercharged thing.
Intake manifold restrictions will not show up on a vacuum gauge. The gauge is on the wrong side of the manifold to mean anything if you suspect your intake of being a problem.
M
This was a good read. I'm looking at options and will run it to get a baseline first. I don't need every last bit of power like a drag car, but don't want to leave a bunch on the table. 25 x 2 is 50 horse so it can add up..
Mr Maine is offline
Old 05-19-2016 | 08:21 PM
  #32
Wrong post
Mr Maine is offline
Old 05-20-2016 | 06:18 AM
  #33
I think you should be close, tuning with a wide band a big plus...you can be shocked sometimes, also the newer carbs, I like quick fuels, are very adjustable thru out the RPM range, another note the prostock engines do pull vacuum at wot for max HP so not sure where the figures come up with runners/carb being to small...theirs sure are not...
ezstriper is offline
Old 05-20-2016 | 07:15 AM
  #34
I agree, there will always be some vacuum no matter what, or air wouldn't flow in. I hope to get some baseline AFR numbers soon.
Mr Maine is offline
Old 05-20-2016 | 09:42 AM
  #35
MER Performance's Avatar
Originally Posted by MILD THUNDER
You sure your throttle was opened all the way?
YES JOE .....not a mistake I make...
MER Performance is offline
Old 05-20-2016 | 09:46 AM
  #36
Originally Posted by SB
How was the exhaust set up in your shop. Meaning, where the mufflers connected directly to the header collectors or how long of pipe before mufflers ? Was pipe same diameter as collectors ?
Without heavy thought, sounds like an exhaust wave tuning issue where the mufflers had you at a better length.
Mufflers are 6 feet away 4" inlet 5" outlet there is a 90 degree elbow at end...Mufflers are truck style.
Old 05-21-2016 | 08:28 PM
  #37
So one side is running mid 12s and the other mid 13s. Because of this I didn't push it too hard into the 4 barrell. Need jets but not sure why the difference. Can float level do this? Motors are both strong and I never would notice this difference without the gauge.
Mr Maine is offline
Old 05-21-2016 | 09:06 PM
  #38
Sometimes, it just works that way. I would treat them as individual engines, and tune them that way. Float level can have a slight effect on that as well. Typically, the higher the float level, the more head pressure there is, and more fuel will flow per a given jet size, the higher the float level is.
MILD THUNDER is offline
Old 05-22-2016 | 09:59 AM
  #39
Ok, I need to get a jet kit and get them tuned in, but they definitely have a lot more power.
Mr Maine is offline
Old 05-29-2016 | 09:14 PM
  #40
I think the old 800 holleys are worn out. One is reading rich and the other lean. When I switch carbs the problem follows so it's not the engines. They are not reacting well to jet changes.
So now is it quick fuel 850s or holly hp950s?
Mr Maine is offline
