How can I tell if my motor is inter or ext balanced
Let u know which way we go ,,,,,we may and just wait a couple weeks when the 496 will be out of the shop and ready to go
How can I tell if my motor is inter or ext balanced It's 1990 502 mag carb I've look every where with the merc serial #. And in does not same or I'm just not seeing it ,,it took a **** I have a spare puppy 489 deal that is inter,,in my v drive ,,,I have to change out the flywheel to bolt up to the bravo drive ..
History on it was it run but not good ...so we go look at boat like it ..awhile c heckling it out ..I forgot to pull kill switch ,just to see if it would roller over easy or was it dragging.type deal ..will it busted off ..and we heard **** load of valve noise ...so I still ran a comp check on the odd bank 90-120 psi..so we knew going in it had upper end issues ,,well I went to hunting the issues ..with my chief mech ,,my wife she a gear head .so we start on the even back and notice the valves not moving like they should ..so we going reset the lash ..and find a bent push Rod ,,,call it a day ..go digging thru my spare parts found a rod ...go to putting rockers on .2 intake valve dropped out ..tunes out the keeper broke ..found all off it ..try to pull valve back up notta going to move ..so ..I start tearing it down to get out of boat ,,,bent valve ..3 piston. Not pretty,,, heads look good other then valve guide on bent hole ..so we r going to rebuild it .,,,I was thinking I could use the flywheel and balance on the 489
[QUOTE=Craney;4467214]Then why did you ask on here, why not just ask her?[/QUOTE
That's what happens when you hit the pipe to early in the day and don't pass it off. Even though you are fken brilliant in your own mind you tend to forget the simple things...
