How can I tell if my motor is inter or ext balanced >
Old 08-05-2016 | 01:08 PM
Originally Posted by jdf4068
Have a set of emi for now that r straight out the tips it's a 9.75 -1 ...with a 680 lift soild roller cam
Should be a good runner. I like solid rollers. Little more maintenance but less frustration with lifter failure especially on aggressive lobes. What's the duration?
getrdunn is offline
Old 08-05-2016 | 01:13 PM
SB
lift tells us little. What are the rest of the spcs ?
Are they (Eddie's) completely dry ?
And will it idle under 1k and stay running when shifted ?
SB is online now
Old 08-07-2016 | 08:14 PM
blue thunder's Avatar
You boys are getting to be soft in your old age because that wife crack would have been hammer down in the old days, but I do kind of miss the fukkery. )
blue thunder is offline
Old 08-07-2016 | 09:54 PM
so replace the ring gear on the 489 on the other side of the flywheel...
dereknkathy is offline
