Rpm issue ideas.... I'm lost.... >
Old 08-10-2016 | 06:35 PM
  #91
Full force, I am following this very closely. Very interested to see what you find. Do you think maybe tight lash, or a lifter pumping up at high rpms/weak valve spring?
I've read the whole thread just thinking of other ideas.
Mr Maine is offline
Old 08-10-2016 | 06:36 PM
  #92
Full Force's Avatar
July 2015.... Has issue.. https://m.youtube.com/watch?v=j_pb2olpIss
October 2015 has issue.... https://m.youtube.com/watch?v=ie_MVroPW9w
Dyno same in February-2016 (see paperwork posted )
Aug 2016 has issue...https://m.youtube.com/watch?v=iurnf_hS8tw
Also seems now even with less jetting the engine will not lean up at all... Really looking at wiring/ignition now
Full Force is offline
Old 08-10-2016 | 06:37 PM
  #93
Full Force's Avatar
I am pretty confident it's not engine mechanical issue, I may be wrong but I just don't see it.
Old 08-10-2016 | 06:49 PM
  #94
Possible it's reversion? Maybe check the risers for carbon wash?
monster12valve is offline
Old 08-10-2016 | 06:50 PM
  #95
Full Force's Avatar
No reversion dry tails.
Old 08-10-2016 | 06:57 PM
  #96
I am having a similar issue. Port motor. I've gone through almost all the same stuff as you. Both run perfect, but port motor down 2 to 300. They were pretty much even early summer.
Mr Maine is offline
Old 08-10-2016 | 06:58 PM
  #97
Anyway it could be a fuel flow issue... After the reg... Or where ever your reading pressure? And maybe the load difference from the dyno and the boat makes the problem occur? Sorry if this all sounds dumb.. Just sounds like you covered most everything... So just trying to think of the oddball things. Do both motors feed from same tank? Maybe anti siphon?
Old 08-10-2016 | 07:01 PM
  #98
Check the filters/screens in the car inlet fittings.
Mark
GETTINBYE is offline
Old 08-10-2016 | 07:03 PM
  #99
If it was that, wouldn't it show lean on the Afr gauge at wot?
Mr Maine is offline
Old 08-10-2016 | 07:06 PM
  #100
Again, different motor stuff but a thought.... How warm did you get the motor on the dyno?? full heat soake operating temp like sustained running?
I have seen things manifest themselves, airleaks, casting pourosities etc only after the motor is completely and totally at operating temperature.
Something like that might not show up after a quick warmup and dyno blast, but after 10~15 minutes of actually running with a load would show up.
phragle is offline
