Rpm issue ideas.... I'm lost.... >
Old 08-10-2016 | 04:30 AM
  #71
Full Force's Avatar
I can feel a loss, at first I hoped it was a tack or off reading but the boats down 2-3 mph also..
Originally Posted by mike tkach
tim,can you feel a power loss on one engine or is it just different tach readings?
Full Force is offline
Old 08-10-2016 | 04:43 AM
  #72
Full Force's Avatar
haha maybe that's the issue!!
Originally Posted by phragle
finite adjustment of the turbo-encabulator?
Old 08-10-2016 | 07:34 AM
  #73
Knot 4 Me's Avatar
Originally Posted by Full Force
I did in fall both engines all 16 within 5 psi across board ..
How many hours ago, though? Might be worth another quick check just to make sure it is nothing internal cropping up. Tranny maybe?
Knot 4 Me is offline
Old 08-10-2016 | 07:42 AM
  #74
I can't see how this would be Stecz's fault, but you never know.......
phragle is offline
Old 08-10-2016 | 08:15 AM
  #75
Fuel pressure the same on both engines?
Mark
GETTINBYE is offline
Old 08-10-2016 | 08:26 AM
  #76
my guess is valve seal issue on one engine.time for another leak down check.
mike tkach is offline
Old 08-10-2016 | 08:27 AM
  #77
Full Force's Avatar
20 hours ago, also remember rpm drop was there before last falls compression testing so that's not gonna be it, also if engine was down a cylinder that would have shown on dyno also.
Old 08-10-2016 | 08:29 AM
  #78
Full Force's Avatar
Why would they dyno identical then? Was down most of last summer, dynoed identical and still down, not sure how that can be a cylinder issue, yes I know I have potential disaster bob cams but if down a cylinder that woukd have shown on dyno. I could be wrong but the issue was there way before dyno, not on dyno then again after dyno, so I don't think it's mechanical in engine.
  #79
Full Force's Avatar
Yes 6-7 psi
Mark
Old 08-10-2016 | 08:49 AM
  #80
KAAMA's Avatar
If it has not been mentioned earlier within this thread, then a leak down test is one of the best tests you can do as suggested here by Mike Tkach....it eliminates a lot of guess work-----and it does not matter how fresh or new the engines are.
KAAMA is offline
