Rpm issue ideas.... I'm lost....
#151
Honestly I have not had many issues with MSD, but not opposed to trying new. One nice things is summit stocks msd and they are local to me.
OK...I am no engine guru, I have been following various engine threads with wide eyes taking as much in s I can because Im collecting parts to do a motor...
Why do you guys keep running MSD stuff when all you read about is people having problems with it. Is there nothing out there better?? or is better a whole lot more expensive??
#152
#154
Yes the bay was flat, with smaller props I saw 70.5 in humid flat water..going to put my labbed 25's back on today, bring them back to 5500..
Yes we will hook up I'm sure, scott was talking PIB maybe hmmm
#157
That was short lived put 25's back on and dropped 200 WOT On port... I give up, these props were even in Zachs boat... Also high 10's to low 11's air fuel at WOT. Lighter load with 23's must have been the fix not the coil. I give up its slow....
Or... I have 3 sets of props with a crap left, but 2 are mint props labbed.. I think next is to swap drives and see if it follows.
#158
#159
Is the reluctor clean? Maybe swap out the magnetic trigger? I'd swap all ignition stuff between the motors before I swapped drives.
As mentioned above about the DUI heir ignitions. . . Pretty simple system. I've been looking hard at switching over all my MSD stuff to DUI or something else in an HEI.
#160
Ok after pulling my hair out thinking again, I called Mild Thunder Joe... We decided it's most likely the extra load on bigger props, making the one emgine go rich and lug, took out 3 jet sizes in secondaries and see 11.6-11.9:1 and both engines 5400 equal, so guess I just needed even less jetting then before the small props allowed the engines to run easier...
I can't say how great of idea it is to have full time widebands to check this stuff! I think we got this now!
