Rpm issue ideas.... I'm lost.... >
Old 08-09-2016 | 09:34 PM
  #61
J-Bonz's Avatar
It's a long shot for sure but are you running choke plates?
J-Bonz is offline
Old 08-09-2016 | 09:35 PM
  #62
Full Force's Avatar
He has, he and I talk a lot... when money is there and I have a MSD fail I will look into it, right now just wanna make these run right haha
Originally Posted by buck35
How did mild not talk you into new programable distributors.
Full Force is offline
Old 08-09-2016 | 09:36 PM
  #63
Full Force's Avatar
no plates on these.
Old 08-09-2016 | 09:37 PM
  #64
Got a plug wire arcing somewhere. Run in the dark with no lights? I know it sounds stupid but problems can show up where you otherwise might not unless you live near a graveyard.
getrdunn is offline
Old 08-09-2016 | 09:43 PM
  #65
Full Force's Avatar
all good, no I am swapping ignition parts tomorrow after work, test this weekend, one part at a time, I didn't mess with things on engines much because of the dyno showing same, but ignition can act up in boat and not on dyno, so I am going to start looking there now..
Originally Posted by getrdunn
Went back and read original thread. I misread the dyno'd after noticed rpm loss with run time. This is a real beiotch. Swap drives or swap engines. Or lose more hair mean while. So to date did you do the coil swap including ign box?
Old 08-09-2016 | 09:45 PM
  #66
Full Force's Avatar
I swapped full wire sets between engines, I am tellin ya I don't almost everything lol
Old 08-09-2016 | 10:22 PM
  #67
Well at least your wise by the one thing at s time scenario. Process of elimination. You'll get it. temps much hotter in bilge than dyno room also.???
getrdunn is offline
Old 08-09-2016 | 10:24 PM
  #68
Full Force's Avatar
Not sure, engines only run at 110 water temp so not a huge change I guess.
Old 08-09-2016 | 10:25 PM
  #69
tim,can you feel a power loss on one engine or is it just different tach readings?
mike tkach is offline
Old 08-09-2016 | 10:28 PM
  #70
finite adjustment of the turbo-encabulator?
phragle is offline
