AFR 325 flow sheets.... anyone ever flow these heads? >
Old 01-09-2017 | 06:50 AM
  #151
SB
I believe way back when, considering his tough to move boat, was low 240 I and mid 240 exhaust.....I'll have to look back at that thread again as I don't remember exactly what I said then. Give me a few.
SB is offline
Old 01-09-2017 | 06:54 AM
  #152
So pretty much what madera gave him
MILD THUNDER is offline
Old 01-09-2017 | 07:06 AM
  #153
Full Force's Avatar
Yes, clearly that worked lol ..
Full Force is offline
Old 01-09-2017 | 07:13 AM
  #154
SB
Duration wise, yes.
I was actually in agreement with the below quote which was on 1st or 2nd page pre build) and thus only replied to his other cam comments later when he thought at the time his 241 at .050" (post build) was too big.
Edit in: I would have not agreed with the 'used' part of it though. I personally don't like the idea of used valvetrain pieces.
Originally Posted by Full Force
I tried to reply, your box is full lol
As of now looking at 242/[email protected] 112 LSA .630 lift... I can get 2 used in good shape, made 690 hp with AFR heads.
SB is offline
Old 01-09-2017 | 07:17 AM
  #155
Full Force's Avatar
So, what do you say I should have now? Just curious because you were way off before... yes I thought maybe it was too big back then, I thought it wasn't pulling up too to get rpm range and it wasn't, but turns out from being too small I learned along since then, all 5 cam guys said wtf is there a 241/246 in a 540 with afr heads for? That's a 509 ci cam not a 540, I'm sure crane, billet cams, Erson, crower, cam motion, comp, and joe, are all stupid and you know what I need.
Duration wise, yes.
Old 01-09-2017 | 07:30 AM
  #156
I see alot of advice and criticism, but really not anyone throwing out camshaft specs or anything.
Just curious.
I believe I've always said it was to small duration and would have gone in the mid 250's w/ 8° split min.kinda like what I ran in my 454's.
sutphen 30 is offline
Old 01-09-2017 | 07:31 AM
  #157
but then again,,I am,,"bottom of the page racin"
Old 01-09-2017 | 07:32 AM
  #158
SB
What the heck ? I think there may be some typing for communication issues going on here. Did I call anyone stupid on this cam talk ? Man o man.
SB is offline
Old 01-09-2017 | 07:36 AM
  #159
SB
Page 3 on his first big thread:
http://www.offshoreonly.com/forums/g...recipes-3.html
heres one
canfield 320's unmolested,10.3-1 compression,single plane w/ dominator(brand eludes me now) and unlike the magical 741 engine,the cam we needed was 248,258,ls112,.629",.629".on the dyno w/ dyno headers made 670hp,,with the dana marine exhuast it made 692hp.enoungh to push a 33 sutphen to a constant and easy 93mph.
ignition system was simple small cap hei and truck coil.I told him to ask for 93 gmc 350 truck parts at napa.
SB is offline
  #160
stop speaking camglish.
