-   -   Custom cam thread (https://www.offshoreonly.com/forums/general-q/341681-custom-cam-thread.html)
MILD THUNDER 10-02-2016 06:32 PM
Custom cam thread
Here's some "custom" cams for oso members that have been specd for their combos.
540ci
AFR 325 heads
9.6:1
1050 CFM carb
Single Plane
241/246 duration
112 LSA
109 ICL
681/663
540ci
GM Rectangle Iron heads
9:1
800 CFM carb
Single plane
239/246
113 LSA
108 ICL
646/639
540ci
AFR 325 heads
9.8:1
1000CFM carb
single plane
242/247
112 LSA
108 ICL
664/656
MILD THUNDER 10-02-2016 06:36 PM
439CI
AFR 265 heads
10.4:1
950 CFM carb
dual plane
234/240
112 LSA
108 ICL
630/615
496ci
AFR 305 heads
237/243
113 LSA
108 ICL
663/664
500 EFI mercury 502
Dart 325 heads
9:1
237/239
113 LSA
109 ICL
639/630
MILD THUNDER 10-03-2016 04:09 PM
This just in
555ci
AFR 325 heads
Procharged
10lbs boost
239/246
114 LSA
111 ICL
644/629
snapmorgan 10-03-2016 04:41 PM
Here is mine if anyone cares
509CI
Brodix 325's
8:1
5lbs boost
241/250
113LSA
110ICL
625/625 lift
Makes 705 hp. idles like a Toyota Camry
This is NOT a MK cam, it was ground by Bullet, so some of you probably know who spec'd it.
phragle 10-03-2016 06:12 PM
You should also list if the cam worked or caused problems. We dont want somebody stumbling onthe the thread and copying something that doesnt work.....
Craney 10-03-2016 06:36 PM
There's no need to send you mine. it's the same as the 496 you already posted.
MILD THUNDER 10-03-2016 06:37 PM
Good point. Unfortunately, I do not have dyno results from all of them, just a few. Some don't even dyno.
What I find interesting, is , the similarities between these camshafts. Whether we are talking about a 440ci big block, or a blown 555ci, there isn't a ton of difference in the cams.
A 9:1 540 with GM heads, gets basically the same cam as a 540 with afr heads and nearly close to 10:1 static. And everyone thinks they are getting some one off highly detailed cam design for their "specific" package. :helmet:
dereknkathy 10-03-2016 07:16 PM
they are. all the other cams fit fords or small blocks...
Lee 10-03-2016 08:18 PM
1 Attachment(s)
Currently running a 60watt bulb, may be upgrading to a 75watt bulb this winter......
Baja Rooster 10-03-2016 08:39 PM
Any reversion issues with that light bulb sucking in negative electrons?
