Oil bypass question >
Oil bypass question
Oil bypass question
Old 10-10-2016 | 03:01 PM
bck's Avatar
bck
Charter Member#568
Originally Posted by 14 apache
Do you have an opinion on the filter media? The 5700 3r and 51222r are interchangeable but the filtering is different. Looks like 1 filters finer particles but actually flows more? The other is tougher and more resistant to heat and water for endurance. I've been using the "endurance" 51222r, didn't even know there was another with the same dimensions.
Straight bottoms and flat decks
bck is offline
Old 10-10-2016 | 03:02 PM
14 apache's Avatar
Originally Posted by JMPH
But remember there is two bypasses,one beside the centre and one below the centre, I took the two out and plugged the one to the right of the centre.
One is for the cooler and other is for the filter. Sounds like you did the filter one.
14 apache is offline
Old 01-19-2019 | 08:23 AM
Does anyone have a part number for the plug
Bajaorlando is offline
Old 01-19-2019 | 09:21 AM
To bypass or not to bypass...
Ryan00TJ is offline
Old 01-19-2019 | 01:08 PM
Thanks Ryan
Old 01-19-2019 | 06:16 PM
These are the valves I got from Summit,for a plug you can use freeze/welsh plug
https://www.summitracing.com/int/par...1284/overview/
AusScarab29 is offline
