I do believe I got bit by my purchase...
that lake in Idaho is really nice. I actually sold some boats in my past to that area from Texas. How bad and cold is your winters ?
Maybe and my good guess would be ---- your oil bypass valve was not set up properly for an oil cooler marine big block.
Welcome to the club! If we had perfect boats then we wouldn't have found ourselves here, so you're amongst fine company. Lol
I was going to mention that many $15k motors have been toasted because of a $15 bypass valve, but BUP beat me to it. Best of luck and hopefully it's simple!
6 month boat storage winters...and I'll search the rest 😩
Do you have a link to a good write up or video on how you set up a non-marine crate motor for a marine application?
Sorry to hear your misfortune, at least it was end of season though. Yours was definately the exception to the rule, one way you can look at it is the motors lasted so long without a rebuild that even if you have to buy a new engine you saved so much not going into the engines your still ahead, Smitty
1st thread here...hoping this site is helpful for my situation...Livin' in Coeur d'Alene, Idaho.
1992 Cobalt 243 originally with a 454/Bravo One...The boat had 244 hours on it total when I purchased it 2 months ago, but was advertised as only 20 hours on the Crate 502HO...Sweet. As I have discovered through paperwork inside the boat what appears to have happened was that there was a Crate 502 (Chevy not Merc) may have been installed in '09 2 owners ago, ran for 15 hours, sold to last owner when the motor started puking oil & had to take it in to Eastside Offshore Marine Service near Seattle...
The Eastside Offshore receipt (August 2011) showed that the motor would not turn over 4200 rpm & was way out of balance...Tore into it to find the wrong crank for a 502 + 2 recently replaced rods...They built the motor with a new crank, new cam & lifters, & showed a dyno break-in of 527HP/570TQ (not sure if these results were with the current Edelbrock RPM intake & Carb). So this was 5 years ago & 20 hours before I purchased it through a consignment that gave me a 30 day warranty for major defects.
So I've had the boat for 2+ months & put 11 hours on it when it started a major knock in the middle of the lake with some pretty good white cap weather...I limped in to the closest marina where I could secure it...then retrieve it with the truck & trailer later. I had tried to get a maintenance base line a few run-hours earlier with new spark plugs, oil change, oil filter, & fuel filter even though winterization was a week or two away. It ran great. On the last cruise I got it up to maybe 55 mph/4800 rpm for maybe 5 minutes...the rest of the time it was a pretty calm run. Oil pressure was great & running cool.
It's been at a pretty big shop but they are in that busy winterize/storage season so there has been a delay. The most experienced mechanic ran it in the tank & said it had a hard miss & thought the noise was in the valve-train...Next step is compression test to pin point the problem...How is that for luck? I'll update when I find out...
What I don't know:
1) Can't for the life of me find the block casting number...but I did find the block casting date stamp of IJ6 (& I don't know what that tells me).
2) The 2011 rebuild by EastSide Offshore Marine states an upgraded Cam & lifters...I tried calling them & the number is disconnected (out of business?)...
What I do know:
1) SUPPOSEDLY the motor was dyno'd by Eastside Offshore @ 527 hp & 570 torque...but not sure if it is with the current top end.
2) Has EMI Thunder Exhaust
3) Has Edelbrock 7562 Performer RPM Air-Gap intake...
4) Has Edelbrock 1410 Performer 750cfm marine carb...
5) Has Bravo One 1.50r w\ a Mirage Plus 19p prop...(this appears to be the original for the 454).
Do you see any problems with that intake & carb vs. the dyno results (are those dyno numbers possible with that carb?), My goal is to get this up and running again while leaning towards more reliable not necessarily faster.
I may pull the valve covers tomorrow (dont have all the tools I need with me now) to get a look at the springs, rockers, & pushrods. I expect some damage. I did get my inspection scope inside one of the covers & see the rocker arms are stamped. I'd also like to get the head casting numbers.
Any input/advice is appreciated. Thanks!
